My tv/av button for my haier TV is not working , i tried to use the remote and directly press the button on the tv , but there's nothing there , it doesnt seem to be working , every button on the remote seems to be working except , the tv/av button
  • 998 Answers
You have a problem in the system control try to check open resistor to that part.
Posted on Oct 15, 2010
Direct tv cannot find a code to program direct TV remote
Hi
The following codes should work with your model
12293,13382 ,10178 ,10000 ,11034
Setup Instructions
  1. Turn on the TV manually or using the original TV remote.
  2. Press and hold the "Mute" button and the "Select" button on the direct tv remote at the same time until the green light on the top of the remote blinks twice.
  3. Using the number key, enter the first digit of the code above. Wait for the green light on top of the remote to flash twice
  4. Enter the remaining 4 digits of the code as above.
  5. Aim the remote at your TV and press the "OFF" key once. Your TV should turn off. If it does not turn off, repeat the steps above, trying each code until you find the correct code.
    www.electro-medical.blogspot.com
Sep 07, 2015 | Haier HL32R 32 in. LCD TV
How can i set up my direct tv remote to my Haier tv
How to scan for TV codes on your DIRECTV remote
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9-9-1, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
Feb 13, 2013 | Haier HL22XLE2 - HL22XLE2 22 LED-LCD TV -...
TCL 21K77 Problem with TV/AV without Remote Control
You may have to find a direct replacement for the remote, no real solution.... Let me know the brand....
Feb 06, 2012 | Televison & Video
Tv remote code for haier tv l24c1180a?
Hello
Four digit universal remote contro codes for Haier TV are:
0081 0216 0217 0157
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jun 26, 2011 | Televison & Video
Ive got a urc-3920 One for all remote . All functions works perfect , but the AV button mutes the TV. Cant change to AV with remote.I've pressed all buttons on the remote to see if it has not been switched...
i have a goodmans tv GTV69RFDT and i have brought a one for all remote urc-3920-urc 3940. All the codes dont work, i have tried the seach method and still nothing is working properly, i get the number buttons and volume but no up channel and down or menu button. Need help
Dan
Nov 03, 2010 | One For All URC-3021 Remote Control
How do you turn on the Backlight on the screen?
If the screen backlight is not on, first try adjusting the brightness.
Press TV/AV button on remote to select TV mode. Press the MENU button on the remote. Using the arrow keys (navigation buttons), choose picture mode and adjust the brightness and contrast.
If your TV screen is still not lighting up in a dim room, then the backlight is broken.
You have 90 days labor and 1 year parts from date of purchase.
Oct 19, 2010 | Haier HLT71 7 in. Portable TV
Sound is operating correctly ..However, there isn't any video , screen has an extremely faint picture
Sounds like a broken backlight. That's a write-off for an old set, or a factory warranty repair (90 days labor, 1 year parts). First make sure the TV is in TV mode (press mode on the set, or TV/AV on the remote).
Once in TV mode, press MENU and use the navigation buttons (arrows and ENTER) to choose the set to factory default mode.
Also make sure you have a working signal by trying another TV on the antenna or cable coaxial wire.
You can also try adjusting the brightness from the MENU.
If these steps do not work, call the Haier hotline listed in the manual: 1-877-337-3639
Oct 14, 2010 | Haier HLT71 7 in. Portable TV
CAN NOT RECIEVE ANY CHANNELS JUST KEEP RECIEVING \...
May 20, 2010 | Haier HLT71 7 in. Portable TV
Remote codes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 09, 2007 | Haier HTF20R21 20" TV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
