Question about Mitsubishi WS-65711 65" Rear Projection Television
DDtv input on my 65711 looks blurry and the color is not right,the other inputs are fine
Most of the time when tv starts to blurr or colors r off, then the bulbs are usually going bad. i would try to locate a local repair and purchase new bulbs. they can get exspensive. they are also different colors. you can adjust the angle of the bulbs.
Posted on Oct 15, 2010
The outside seens and peoples faces are not the correct color. The picture comes in as a blurry pink color
Try connecting the same input to a different TV. If it works there, try connecting a different input to the TV. If the same problem is noticed, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung LN40B530 40 in. LCD HDTV
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
I have a DX-L26-10A that has problem with the A/V inputs. The picture is fuzzy. All the other inputs on the TV have a good picture. Both A/V1 and A/V2 are fuzzy.
AV1 and AV2 are Composite signals. What this means is that the Image signal and the Image color are combined into a single feed... or a composite or signal and color. Other than using CH3 from the cable box, this is the poorest performer in regards to signal quality. Additionally, the signal only has 480 lines of resolution and your TV has 720.
What all this means is that 480 lines of poor image quality are being blown up (think magnified) to fill 720 lines of resolution on the screen. What you end up with is a blurry image when compared to other inputs (ie: HDMI, COMPOSITE). The Dynex TV does not have some of the more advanced video processing of other manufactures. It will perform the image doubling, a bit of filtering, but not much more.
I suspect you TV is fine. A transition to an HD display can be shocking to some. After all, the VCR looked better on the old analog TV (not a joke, it did).
I hope this was helpful, best wishes.
Mar 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I have a RCA Hd52w59 television that has a blurry red green blue colors on screen and the pics looked like they are caved in .any help ?
RED BLUE and Green are the component colors. If you are using component cables, which most likely you are, check to see if the Green has come unplugged. Try switching the cabls to a different input. Actually, if you get the same problem on another input that say....your DVD player is hooked to, you have a bad tv. If not, try to isolate it to the simplest thing first e.g. cables, input source, etc. Please don't forget to rate this solution for me.
Jan 21, 2011 | RCA HD52W59 HDTV Projection Television
I have a H1080 projector. When i plug something into th HDMI1 input the video colors are wrong. They are almmost neon like i dont think its the settings because when i plug the exact same thing into HDMI2...
the hdmi one plug is set to only recognize a 1080p picture anyting less and you get or kind of blurry and very colorful picture took me three days myself to figure it out simply turn the setting on hdmi one to accept not only 1080p but lower resoluttions as well.
Jul 01, 2010 | Televison & Video
WD 57733 picture color problem
Good Day;
Try resetting both devices TV & BOX, unplugg power for 2 to 5 minutes then plug back in.
good Luck, big IRISH.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Daewoo DP42SM coloring missing blue tint on dvd playback only
I don't know are you familiar with electronic,if you are you can fix it by yourself.The problem is in video process board,the one in metal cage.What you need to do is to remove the board from the set,remove the cage, then to replace all SMD capacitors!!!And do not put SMD as replacement put the normal capacitors same values they can be fited.You should aslo replace capacitors at the PSU and check 170V,160V and 70V and adjust them after the replacement.PSU is easy part but the video board is tricky one but it can be done
Feb 15, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Mitsubishi WS-65711 65" Rear Projection Television Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
