Question about Casio Atomic Timekeeping Waveceptor Watch WV59DA
B button stuck after getting battery replaced
The day changer is stuck inbetween two days and the day wheel does not respond with pressing of the button at the 10 o'clock position
Mine has just done the same today, stuck just before Thursday, tried the soft touch button at 10 o clock with no success, I will see if anything happens over night if not I will be expecting it repaired or replaced under warranty. How did you get on with yours?
Apr 05, 2014 | Longines Watches
Womens Tide 3G FS80963 Watch My watch went blank. I've had it for only about 6 months- so I don't think it is the battery. I had just checked the time in my car, pressing the light button and it was...
Your battery may indeed be dead. Watches sometimes sit on store shelves for months and even years before you get them. If you have a stuck button it may be the light button and may have prematurely drained your battery. Either way a watchmaker would be able to determine the problem.
Mar 09, 2011 | Freestyle Tide 3.0G Black FS80963 Watch...
I have a problem whit my Casio W94HF. It just stop working. It show the time but you can't push any button until I reinstall the battery help me please :)
usually when the watch still works but you cannot make or change any settings and you do not see any reaction or change when you push a button, then it means that one of the buttons is stuck (as if permanently pushed) and the watch will not react to any button until the stuck button is released. Inside the watch there are metal fingers (contact blades) that the buttons actually push, and sometimes one of these finger blades can get stuck even though the button has returned outward. try (with tweasers) to pull on each button to see if it will move outward and allow the watch to start functioning again. If not, then the watch must be opened,and with a fine pin-like probe, each metal finger blade must be tested for proper movement and position. Also, when a battery is replaced, occasionally the housing is not seated correctly when the "movement" is replaced in the housing (if it was removed in the first place), when the cover is back in place, if there is a plastic or metal bezel ring, maybe the ring is not seated correctly. goodluck, Macgivor
Jan 27, 2010 | Casio W94HF-3AV Wrist Watch
Just replaced battery in RSS210...now ony the set button works
How old is the watch? The buttons could have a build up of dirt around the buttons and that will keep them from working! If thats the case you can take a pin or a very thin screwdriver and run it around the botton to unclog the build up...or you can also take it to a reputable watch repair shop and they can disassemble the watch and remove the buttons and clean it really well.
Its also possible that the watch wasnt assembled correctly when it was closed after the battery change as well. Some movements have a small metal flap that the buttons push against to work the functions. If the flaps get moved then the button might be pushed in and stuck since the flap doesnt push the button back out...OR...there is a tiny little c-clip that holds the button in place and if thats removed then the button might not push back out or could come out of the case all together!
So...check around the button for a build up of dirt first, try removing the dirt with a pin or small screwdriver. If the button comes out then put it in a plastic bag along with the watch so you dont get any moisture inside and take it to a reputable watch repair shop! :-)
Jan 18, 2010 | Timex Ironman Triathlon Bodylink Watch...
All I did was press the light switch and all of a sudden it went blank so I can't do anything now
The light button drains the battery real quick.  Can happen accidently when put in your pocket or when the button is stuck.  Put a new battery in the thing.
Nov 15, 2009 | Watches
Nike triax watch
sounds like the contact inside for the ligt button is stuck on. Remove the back again and take a look at the contact under the light button to see if it is stuck, if so, GENTLY pry it out a bit so it's not touching all the time...
GOOD LUCK
Jan 27, 2008 | Nike Triax CV10 Wrist Watch
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Casio Atomic Timekeeping Waveceptor Watch WV59DA Logo
81 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
