Question about RIM BlackBerry Curve 8520 Smartphone
No sound when i answer my cell, I can only use my headphones or put it on speaker. So is the sound card damaged or do I need to load a sound program back on it?
  • 560 Answers
Earpiece may have been damaged or dirty. It is advisable to have your unit checked by a qualified cellphone technician to avoid further damaged.
Posted on Oct 15, 2010
What is wrong with my sound?
You need Togo to the sound properties or settings and put the speakers as default. Or maybe update the driver for your sound card.
May 26, 2014 | Sony VAIO VGC-LT23E 22" PC/TV All-in-one
My headphone jack is not working at all. I just purchased it today, the sound card is saying no errors, the sound plays fine out of the speakers and the headphone do work Im using them on my cell now
Take it to the Service center. need to replace the headphone output connector's. these will happen from Moistor,Dirt block or Dry solder in the Laptop Motherboard. best of luck. ( Try, put headphone jack in and out for 20 to 30 times, or check the sound comes out via headphone, when pressing the connected jack.) best of luck
Feb 01, 2011 | Sony VAIO VPCEA36FM/W Laptop
After pluging my desk top to an external speakers ther was aspark and then there was no sound in my desktop what i should do i checked the control panal it say sound is working properly should i put a new...
The external speakers most likely generated electrical feedback to your computer. If you can plug in headphones and get sound from them, then your computer's sound card should be OK. If not, then the electrical feedback has damaged your computers sound card. Sound cards are fairly inexpensive thankfully.
Sep 27, 2010 | E-Machines eMachines Desktop PC
Hi, My Saffire LE is making a crackling sound. I have check this on both the monitoring channel and the second out put on my HS80's and also on the headphones out put on my AGK's, the crackle is...
Power sound amplifier output transistor push n pulls are dead and the q point is off the scale.
Either it is a modular amp or discreet top hat xistors
Aug 23, 2010 | Focusrite Saffire LE FireWire Audio...
When I turn my speakers on there's a buzzing sound all the time, and when I put my headphones in, it's even louder, (in the headphones of course). What can I do???
Check your sound card hasnt came loose, make sure there is no router or hub of any type near your pc. nothing much after this check wiring for shorts. if you listen to the music to load all the time it can damage the amp. try plugging headphones into where the speakers normally go on your pc , see if the hummms there if not then its just your amp on its way out.
Dec 02, 2009 | Altec Lansing VS4121 Computer Speakers
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
My left speaker on my gateway ML3706 laptop just stoped working
If you get sound from both sides of the headphones when you plug it into the same jack the speakers normally plug into all you need to do is replace the speakers. If you mean you plug the headphones into the cd drive that's nothing special. You could have a bad sound card, bad connection in the jack, or bad speakers.
Jun 20, 2009 | Gateway Computers & Internet
Realtek Sound device problem
i dont have a volumecontrol
Jun 02, 2009 | Computers & Internet
Cant get sound through my headphones when i plug it in my computer
You need to check the headphone jack on the case before you try to use it again. It may have a wiring problem, Shutting down the computer is a serious problem and could do a lot of damaged to windows program and you computer.The way to reset the case headphone jack is to go int the control panel and search for the sound control device. go to the advanced options and put in the type of device you want the sound to come from. There is also the possibility that the headphone jack was damaged when you had your problem and will no longer function correctly. Hope this helps you with your problem.
May 17, 2009 | Microsoft Windows Vista Ultimate Edition
The speakers on my laptop do not have any sound. I can hear sound only when I plug in headphones. Is there a way to switch speakers? I have a Compag Presario v2000
You could have damaged the sensor in the 3.5 mm headphone jack so your computer does not realize that there are no headphones plugged in. If thats is the case you will have to have the sound card replaced. Another problem could be that the driver is messed up if you recently updated drivers roll back the sound cards driver or update it. Finally you can simply hook up old non usb speakers that use the headphone jack.
Jan 08, 2009 | HP Compaq Presario V2000 Notebook
RIM BlackBerry Curve 8520 Smartphone Logo
208 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
