Question about Dell XPS M1330 Notebook
WHEN I PRESS POWER BUTTON THAN LEFT SIDE THREE LOCK SYMBOLE ACTIVATE AND IT,S NOT GET START
  • Dell Expert
  • 393 Answers
Check the rams.. remove and clean if not ok then change ram and check hope will b okie
Posted on Oct 15, 2010
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
Tip
AOC monitor Lock-Unlock instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
on Apr 25, 2010 | Computers & Internet
I just opened my tablet iconiatab a500snid12914106415 and the home button does not seem to work
there is no physical home button for the iconia. it has power to left. you have to hold to activate. hdmi to lower left. volume is on top. next to volume is rotation lock.. to the right is power and bottom right is usb ports. on screen will be back button, home button. and options button. since these are onscreen you could turn off rotational lock and press onscreen button on a different side.
Aug 23, 2011 | Computers & Internet
Osd Lock how to open?
http://s807.photobucket.com/home/budm/allalbums
Jun 14, 2011 | AOC 917Sw 19" LCD Monitor
AOC LCD MONITER OSD LOCK
Apr 24, 2010 | AOC 917Sw 19" LCD Monitor
Key lock imate sp5
Press the power button on top, and select '3' Key Lock.
Unlock using (Left-Menu)button & *
You can setup a timed lock, but this requires a 4-digit PIN to unlock which is a hassle for normal use.
Jun 26, 2009 | i-mate SP5 Smartphone
I can't lock the car using the remote key. the light flashes on the key but does not lock the doors
try reprograming the remote, if that doesn't work u may need a new remote these are the factory instructions.
1. Switch ignition on with a key (don’t start the engine!); leave key in the ignition.
2. Mechanically lock vehicle at left front door, using second key.
3. On remote unit, press "Open" button once. A short horn signal will sound.
he "Open" button is pressed once for programming the first, or a single,
remote unit.
�� When programming additional remote units for the second, third or fourth
memory addresses, press the "Open" button two, three or four times, in
one-second intervals.
�� Example: press the "Open" button once, wait 1 second, then press once
again to program the second remote unit.
�� After 6 seconds, press "Open" button once to activate the coding ocess.
4. The remote unit will now be coded, and it can be used to unlock the central
locking system. Switch ignition off.
The key must be removed from the ignition before the remote unit can be used to lock
the vehicle.The coding process can be repeated up to 4 times for additional remote units.
In between each remote unit coding, the ignition must be switched off.
Apr 10, 2009 | 2004 Volkswagen Jetta
I'd like to lock the keypad of my HTC S740.
To lock the keys so you don't accidently activate the phone whilst carrying it about.
Press and hold down the "end call" button ( phone handset down picture) until Unlock shows at bottom left screen
To unlock, press the top left button, above the "start call" button (phone handset up picture), then press the * button (bottom left).
You get a screen prompt to press * to unlock
Mar 06, 2009 | HTC S740 Smartphone
Can't take child lock off Emerson microwave 8117
From the owner's manual:
CHILD LOCK
1. To activate, press and hold the STOP/CANCEL
button for three seconds, the display will appear as
shown at the right and no buttons can be pressed.
2. To deactivate, press and hold the STOP/CANCEL
button for three seconds, the display will return to
the time.
If for some reason you dont have your owner's manual, you can download it here.
Dec 11, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Dell XPS M1330 Notebook Logo
57 people viewed this question
Alun Cox
