Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
I HOOKED UP THE CABLE AND GAME SYSTEM TO THE TV AND THE PICTURE IS MILKY WHITE THE COLORS ARE DISTORTED AND THE PICTURE IS EXTREMELY BRIGHT NOTHING COMES IN CLEAR I CHECKED TO SEE IF THE THREE BULBS ARE FUNCTIONAL AND THEY ARE I TRIED AUTOMATIC CONVERGENCE AS WELL I REALLY WOULD APPRECIATE ANY TIPS OR ADVICE OR AN RESOURCE TO UTILIZE SO I CAN GET IT FIXED
  • 998 Answers
Try to check the connection you might connected it wrong or look for the manual of your tv. just write your concern again you tried it thanks im willing to help.
Posted on Oct 15, 2010
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Mar 06, 2012 | Nintendo Wii Console
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
JVC AV27S33 tv black and white
I would guess you are using an antenna or a cable service without a set-top box.
When the TV is using HDMI or component video it does not employ the decoding for the color as like when using an RF feed. Most people of today do not use RF directly in to their TV set using the built in tuner. They feed a desk-top box that feeds a decoded picture in to the set via the component RGB connectors, or they are using HDMI.
When viewing an RF signal from the antenna or cable using the TV's internal tuner, check the video settings. make sure the setting for Color is turned up to 50% of its range to start with. If there is no color, check to make sure the Settings are correct. Check to see if the TV has a black and white mode, and this mode is turned on.
Check to see if the TV receiver section is for your location type. If you have a set from another country that uses another broadcast system for color this can be an issue.
It is also possible the TV set's color decoder for RF reception is defective. This would require proper service. You would not be able to service this yourself.
Based on the info you supplied these are the best suggestions I can think of...
Mar 11, 2017 | JVC AV-27S33 27" TV
Games are in black and white-no color
Make sure the cables are hooked up properly. Audio to the audio input and video into the video input of the tv.
If they are hooked up right and you still only get black and white pictures then the cable might be bad so get a new cable.
If you still have a problem even with a new cable then its something to do with the connector in the SNES or the main board itself.
Ben
May 21, 2009 | Nintendo Super NES Console
Distorted Picture
I don't think that the cable is your problem. Set may have a defective tuner or small signal board. (Tuner is soldered onto the small signal board).
Most likely fix is to find and replace the small signal board with tuner. Should be able to find one for less than $200.
Another thing to try is your video inputs. Use external devices such as a DVD play hooked you using proper video lines and check you inputs. Are they doing the same thing as your cable? If not, then it maybe just a tuner. Some makes and models won't allow you to solder in a new tuner without a full board replacement, but this however may allow you to hookup a VCR with a tuner built in and from VCR to your TV using video input jacks and then programming the VCR tuner to all your cable channels may get your set watchable again without having to tare it apart and replacing a board. However if your input jacks are distorting like the cable channels are, then a small signal board replacement is a must for your set.
Jason
Dec 29, 2008 | Sylvania 6626LCT 26 in. LCD Television
Color picture for my wii
maybe the component cables are not working, try buying a new component cable.
Dec 26, 2007 | Nintendo Wii Console
How to get colors on tv
sound but no picture
Dec 11, 2007 | Koss KS3102 System
LCD Toshiba TLP s10
You probably have the input set to component video (Y/Pb/Pr) which will distort the colors
Oct 23, 2007 | Hitachi CP-X270 Multimedia Projector
TV Problem
picture is milky white is due to crt.if it is old set. or check video section
Sep 20, 2007 | Zenith B25A10Z 25" TV
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
