Question about IBM ThinkPad R52 Notebook
Help with USB
Hi i just reinstalled windows xp. Are there any drivers i have to install for the usb ports because when i plug a device in it doesn't recognize the device. If so does anyone know the website? Thanks alot
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
This seems to be a common prombelm with xp try unhooking the usb item and turnig of computer and rebooting it, then connnect usb item and go to add and remove hardware when it ask it you have connected it yet connect it and item and it should reconize it if it doesn't get back with me and maybe we can think of something else to help you .lala linda
Posted on Jun 03, 2008
When i try ti install my printer i get a meaasage saying "the specified location does not contain information about your hardware" what does that mean?
The message means that the printer driver is not available or is corrupt. You can click on the link below and download the driver and start fresh.
Click Here >>> iP2600 Driver
Also, below the is screenshot of the website, click on Driver & Software button and select your Operating system to get the specific driver.
Regards,
Shrey
Jun 02, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
I have a biostar motherboard G31-M7TE with XP the instalation disk installs USB 2.0 ok, but now i installed Vista and planning Windows 7 too , but actually with Vista my USB is 1.0, too slow, it...
Access the Windows DEVICE MANAGER.
Select the USB hardware.
Click UPDATE DRIVER, and see if Windows Update can download and provide the correct device-driver to enable USB 2.0 support on your USB 2.0 ports.
Or, try: http://www.biostar.com.tw and see if the updated USB device-driver is posted on their "Support
May 19, 2010 | Biostar G31-M7 TE Motherboard
I reinstalled my OS win XP . now no usb
Open Run and launch regedit
Browse to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\USBSTOR
In the right pane, look for an entry named Start. If you find one delete it. Your USB devices should start working immediately.
If not please report back.
Nov 11, 2009 | Acer TravelMate 240 Notebook
System freeze
The issue was resolved by uninstalling SP3. I uninstalled SP3 and the USB PCI card and rebooted. When SP2 reinstalled the device it installed the corect driver (5.1.2600.2180) and everything is now functional. Have no idea why the correct driver was not in XP SP3.
Jan 24, 2009 | SYBA (SD-NECU2-3E1I) (SD-NECU2-3E1I) USB...
T40p usb 2.0 ports acting like usb 1.0
There is no hardware or software fix for this. Here is a thread on what might be your problem. http://forum.thinkpads.com/viewtopic.php?t=67571
Sep 14, 2008 | IBM ThinkPad T40 2373 Notebook
HI HAVE PROBLEM MY HP PHOTOSMART C4280 I TRY TO SCA AND TELL ME NO USB PLEASE HELP
You can try making sure the cord is securly attached on both sides, and make sure the computer is recognizing the (assuming)scanner or all in 1. You might also want to try reinstalling the driver for the printer.
Jul 18, 2008 | Office Equipment & Supplies
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
IBM ThinkPad R52 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
