Question about Microwave Ovens
The microwave is stuck in "locked" - Microwave Ovens
  • 618 Answers
On most brands you press and hold the same button that locks it .
Posted on Oct 15, 2010
NN-ST671S microwave is locked and wont function Is their a childproof lock on it and how do you unlock it
There should not be a childproof lock on your microwave.
However, it is remotely possible that there is electrical failure preventing the door opening.
Most, not all, microwaves can be taken apart with screws with the door closed.
See if you can do yours.
You should find the latch holding the door is broken or stuck or whatever.
God bless your efforts.
Nov 13, 2017 | Microwave Ovens
How do I get the microwave to stop beeping.It"s beeping and locking the controls by itself.
The touch pad sounds like it is trying to tell you it has a stuck pad. The touch pad will need replacing.
Oct 01, 2014 | GE Microwave Ovens
Our Kenmore Microwave Hood combo model # 401.88529011 door sticks and is very hard to open off and on
Possible that the door lock is jammed, it can also be due to jamming of the door switch or the plastic lock being stuck on.
You need to remove the front panel , and reset the door assembly.
Jan 25, 2013 | Kenmore Microwave Ovens
Door wont latch
Possible that the lock switch had broken or that the alignment of the lock is offset. You can remove the front panel by removing the screws on the sides and slide out the panel to get a view of the lock which wil confirm the case. If so the lock must be replaced or if broken and the piece is found within , it can be stuck together using instant glue.
Jan 11, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Rc17 commercial microwave, display shows door even when door is closed.what can i do to resolve
Possible that the door lock switch is stuck and so is not releasing even after the door has opened. Look inside after disconnection of power to the microwave at the place where the door locks. Tap into the lock to release the switch . If the switch is jammed or damaged it must be taken out and replaced.
Mar 31, 2011 | Amana RC17 Microwave Oven
My Sharp R-1870F microwave in our rv heats intermittantly and the turn table is stuck. Any advice?
Check the oven door if it locks up, the oven has an automatic feature that when it is not closed properly it won't initialize. Since it heats up intermittently I think the heating capabalities of the microwave is still good, and this problem might be just due to something that is preventing it to operate. which most likely the the locks of the door.
Jul 07, 2010 | Sharp R-1870 Convection/Microwave Oven
Microwave Buttons Stuck
You have a bad control panel contact LG for a new panel.
Jan 24, 2010 | LG LMV1630 Convection/Microwave Oven
Constantly beeping with lock signal on
Sounds like you have a defective/stuck switch associated with the door lock mechanism. There are 4 and possibly 5 interlock switches. Simply operating the switches may enable you to locate the problem switch. You will have to remove about 10 screws to remove the top cover, to gain access to the interlock.
Best of luck.
Jan 21, 2010 | KitchenAid KHMS155L Microwave Oven
How do i change a fuse in a kitchenaid overhead microwave
Hello,On the front of the microwave above the door is a louvered panel. You need to remove the panel ( usually it just pulls straight off ) and inside on the left you will see a metal rod that's bent 90 degrees. That is the lock handle. While lifting on the front of the microwave pull that handle out to release the lock. The front of the microwave will tilt down, you may have to help it start tipping. Once the microwave is tipped down you have to lift the back that is against the wall to unhook it from the wall mounting panel. Be careful to feed the power cord through the cabinet hole as your lowering it. Good luck and let me know how this works.
Jan 02, 2009 | KitchenAid KHHS179LSS Convection /...
Stck in locked mode
Try holding down the clear button for 3-5 seconds
Mar 14, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
