Question about Kenmore 55683 Stainless Steel Side by Side Refrigerator
Measured Fill not Measuring Properly
Everything on my Kenmore 55683 is working properly, except for the Measured Fill feature. It measures slightly over the amount requested, usually when set to "ounces" setting.
4 Suggested Answers
the dr
  • 447 Answers
SOURCE: kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Posted on Dec 04, 2007
lancer721
  • 229 Answers
SOURCE: kenmore elite refrigerator. both compartments
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Posted on Nov 27, 2008
heatman101
  • 43501 Answers
SOURCE: I have a kenmore Elite
Try setting the freezer temperature a couple of degrees lower then reset the fridge temperature lower...You may not have enough differential between the freezer and the fridge temps...
If it still does not work right then check you manual and reset everything back to factory settings and start over...
if that does not work then you have a bad board...
heatman101
Posted on Aug 24, 2011
My Fisher & Paykel (Model E522b) refridgerator's LCD control panel is not working. The display only shows the headings (measured fill, ice, and settings).
Hello Carolyn Le Coyte,
Your model number SEEMS to be abbreviated..
( took the LIBERTY of searching for a E522BLXU
MODEL which discusses both "MEASURED" and
"NON-MEASURED" fill features...
I am thinking your MENU has been locked...
(you should ORDINARILY be able o scroll
through your MUNU ITEMS)...
See instructions manual:
Fisher Paykel E522BLXU Service Manual Nonmeasured Products Products...
Specifically go to "menu lock"
Hope this helps
Carnac the Magnificent
Aug 21, 2017 | Fisher Refrigerators
Is there a way to calibrate without 3-50 pound weights?
water weighs 10lb to the gallon ( engilish measurement-calculate amount for us gallon)
so get your self a jug and place it on the scales empty adjust the scales to zero
fill the jug with a measured amount of water (example 1 pint will weigh 1.25lbs
then set the scales to the reading of 1.25lbs
to check the scales accuracy you can add extra water to the jug (say 4 pints ) and the scale should read 5lb
Jul 25, 2015 | Office Equipment & Supplies
How do I check the level of a manual gearbox on a 2002 Peugeot 607 hdi
you will need to consult a manual, some gear boxes need a measured amount of oil in them and the only way to measure is to drain and measure, others have a filler plug on the side of the box and these type are filled with oil until it starts to trickle back out ,don't over fill
Mar 02, 2015 | 2002 Peugeot 307
Samsung flatscreen turns on but screen does nothing. HELP please.
Check the internet. Most likely a series of cheap capacitors. Replace them all (the ones that match the culprit). ~.20 each US.
May 30, 2017 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung TV will not turn on.
OK if it is LCD your and have sounds but no picture you possibly have faulty inverter board that need to be replace
Dec 03, 2012 | Samsung LN-S4692D 46 in. LCD HDTV
Looking for the proper dimensions of an 03 harley roadking dipstick from bottom of plug to top of fill mark and top of add mark
I want to help, but you may have to go to a H-D dealer and measure a dipstick for an '03 Road King. I have an 09 Ultra Glide. My dipstick (measured from the "lip" that sits on the oil fill opening to the "add" and "fill" marks) is: For bike on jiffy stand - 5 3/16" to full and 6 1/16 " to add. For vehicle upright - 4 15/16" to full and 6 3/8" to add.
Jul 30, 2012 | 2002 Harley Davidson FLHR - FLHRCI Road...
I have trouble steering...the truck wanders over the road...i have replaced idler arms, pitman arm, center link, shocks, brakes, new tires, front end alignment, bearings...the right front tire sits...
when the steering wheel is centred, the front wheels should both point slightly inwards.
after the amount of parts changed, i would recommend that you get the tracking checked at a garage using the proper, calibrated measuring systems, to make sure that the steering is set up properly and safely.
Mar 30, 2011 | 1992 Toyota Pickup
Yz125 rear shock amount of oil on
The volume is less than about 1/2 quart - it's usually not measured going in since you fill the shock completely - there's no need to measure. Some guys assemble the entire shock, then fill with oil and cycle the shaft, then install the bladder cap last. My method is to install the shaft and seal head and the bladder, then put about 2 PSI in the bladder, then bleed through the compression cap. My method is a bit more complicated to explain, but it's effective at eliminating ALL the air from the oil and it keeps the bladder from being installed in a collapsed state.
As far as the nitrogen charge - 145PSI is stock. 130-160PSI is typical.
Apr 30, 2010 | 2004 Yamaha YZ 125
Kenmore 55683 Stainless Steel Side by Side Refrigerator Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
