Question about Hotpoint HSM25GFRSA
HSM25GFRA Hot Point side/side not making ice - Hotpoint HSM25GFRSA
  • 618 Answers
Check the inlet tube to see if it has ice in it .
Posted on Oct 15, 2010
Hsm25gfra sa. Bought used, was told ice maker didn't work, so haven't hooked any of that up. Problem: water/ice is pooling in the bottom of the freezer section. Every day or two it leaks out. I'm...
The refrigerator has a blocked condensate drain line. In most Hotpoint models it is easily accesed by pulling out the bin at the bottom. There should be a drain grommet at the center of a trough in back. This plugs up. You may have to pour hot water the thaw out the ice and then either blow out the drain tube or I use a 5/15 plastic hose and push it through the drsin to clear it out. this should fix the problen for a long time. Food particles etc. collect in the drain and ice forms around them and blocks the drain.
May 17, 2014 | Hotpoint HSS25GFP Side by Side...
Tip
Hot point side by side with ice maker
My Hot point side by side has water and ice dispencer, when we use the ice maker the trap door stays open we have to close it by pushing it with our finger. We tried some lubricant on the hinges still stays open. We were wondering if there is a solinoid that acuates the door closed.
on Apr 30, 2008 | U-Line CO2075F-B Echelon Refrigerator Ice...
Have a Hotpoint model HSM25GFRA SA Ice maker stopped did some checking ond found the water solinoid to ice maker was open and replaced it. But still no ice, have removed ice maker, cleaned and defrost
Check to see if there is ice blocking the tube to the icemaker. Sometimes when the valve is giong bad or the icemaker sits too long without making ice the tube will freeze and block up with ice.
Feb 14, 2014 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint side by side refrigerator model number hsm25gfra sa and the fridge keeps getting warm. after about a week or so I have to unplug it and let it sit for a day or two, than I plug it back in...
The coils in the freezer are probably freezing up. Do you have ice buildup in the back of the freezer? I would replace the "defrost limiter thermostat". Here is a link to the part you need.
Here is a video to show you how to replace it. This is a different model but the process is the same.
Oct 17, 2012 | Hotpoint HSS25GFP Side by Side...
Divider between side by side compartments hot
The area arond where the seals is heated to stop the seal getting damp and mouldy.
Apr 17, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
My hot point frig is not making ice
tempt needs to be 15 deg or lower in freezer / ck for frost build up inside at the back . make sure fan under neat and in freezer is going . clean coils undrer neat. . you could have a bad ice maker / but do these things first . mm .
Dec 07, 2009 | Hotpoint HSS25GFP Side by Side...
I have a GE Hotpoint Side by Side refrigerator Model #HSM25GFRA SA and have a problem with the water dispenser. I've switched out the filter with two new ones but still have the same problem - no water...
Alot of the GE refrigerators have problems like this. You either need to replace water valve on the back because one of the valves has stopped working OR the tube in the door has frozen and the door will need to be replaced. The best way to tell is remove the hinge cap on the bottom hinge and disconnect the little adapter put a towel down there and then trigger the water dispenser. If water comes out, the tube is frozen in the door. If not, replace the valve.
Jul 15, 2009 | Refrigerators
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
Fan oscillation
Probably damaged the fan blade. If plastic, it could be missing a blade or maybe cracked. If metal, probably bent. I would ttry to get an eyeball on it while it''s running to see just what's up. Fan motors are usually pretty durable and last quite awhile.Good Luck and hope this helps.
Mar 15, 2009 | Hotpoint HSM25GFRSA
Hotpoint HSM25GFRSA Logo
65 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
