Question about Canon FAX-JX200
My fax machine is in auto print off mode how do i switch it to auto recieve mode
    Guru:
  • Canon Master
  • 452 Answers
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Posted on Oct 17, 2010
There is nowhere I can find whether I should switch on the Machine 24hr a day x 7 days a week. Or shall I swtich it off after-office-hours? Any effect on the life-span of the machine?
In a business environment most fax machines are left on 24/7......who wants to miss an order coming in because your fax was OFF. However, many fax machines can be programmed to go into a "sleep mode"...this would be in the evening when the office is closed...you still want to be able to recieve fax's if any come in..but you don't need the machine ON "fully" ready to print. Another-words, the machine is in a sleep/half power mode( because no-one is in the office to use it )..BUT if a fax comes in then the machine can still recieve it, then it "wakes-up" fully..prints out the recieved pages, and then goes back to sleep again. The details on how to program this function will be in your operators manual IF the feature is available on your model.
The benifits of programming a machine this way are pretty obvious...savings on Hydro, extended machine life ( due to machine going to sleep.) and yet you still dont miss any calls.
Pretty good hey.!!
Nov 07, 2010 | Brother IntelliFax-2820 Laser Fax
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
Auto print off
Under service mode MENU and # select clear, and all.
After thath fax is returned on factory sett. Reenter your set. and fax will work.
Jun 09, 2010 | Canon FAX-JX200
I can't recieve faxes
Check the reception mode of your fax. There are multiple modes that it can be, such as, Auto, Manual, Tel, etc...For auto fax reception, make sure you select "Auto" or "Fax" mode. This is usually done with a Rec Mode button on the operational panel of the machine.
Dec 11, 2009 | Office Equipment & Supplies
My canon fax jx500 is saying autoprint off and we are unable to receive any faxes. how do i switch it ''on''. can't find it in the menu anywhere
hi rebecca you have to Press the on / off switch once, this will switch the machine's fax to auto receive mode. Press and holding on / off switch causes it to power off.
Dec 02, 2009 | Canon FAX-JX200
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
My fax machine says enternal tad.
TAD stands for telephone answering device. you have to change mode to either fax or phone/fax.
Auto answer is also another option on some faxes
Jun 22, 2009 | Brother FAX-575 Plain Paper Thermal
Recieving faxes automatically
you have to set machine for fax mode by pressing auto answer button on key pad of machine. then you have received faxes automatically.
May 04, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
Fax issues
yes press fax button and go to setup/ press setup. printer setting and reset menu and select option to reset to default and when you configure settings on your printer for fax feature disconnect line from the back of printer and configure it then when finish reconnect the line and powercycle printer. then test by sending nd ask someone to send you a fax as well.\
make sure incoming mode is set to auto switching and drpd to normal or on
Dec 19, 2007 | Epson ACULASER CX11NF All-In-One Printer
Canon FAX-JX200 Logo
333 people viewed this question
old marine
old marine
