Question about Maxon HCB-10C CB Radio
I dont really have a problem i just wondered how to get out farther mike gain wise and how to get it to hear farther
    Guru:
  • 773 Answers
Well, its a hand held. Not really known for the best range. But in order to make it get out better the only thing you can really do is peak and tune it. That will make the radio put out more power.
I have never worked on this radio, so I couldn't tell you what modifications you would need to make. If I had the radio in front of me I could do it. But I looked and cannot find a schematic diagram of this radio, so there is no way I can tell you how to do it.
However, if there is a CB shop in your area you can take it there. They will charge in the ball park of $30.
If you want to send it out, you can contact http://www.bellscb.com/ and then send it to them, and they will peak and tune it. They are a good shop. Not sure what they will charge, and there is also shipping.
As for receive, there's not much you can do. It's all about your antenna. If you put a base antenna like an antron 99 in a tree and use an adapter to hook it to where the antenna goes, then you would have much better receive. As well that would also help you get out better. However the radio would be much less portable. But you could set one up at your home for when you use it at home, and just plug into it when you want.
Posted on Oct 16, 2010
What size do l need
That depends on you really BUT
Take into account the room size, mounting wall placement size and most important the distance from where you watch to the TV. also consider where you place it when daylight comes in.
Like bedroom a 32" say, family room the farther you set from tv the larger the tv screen 42"good 60" great but only for larger rooms
hope this helps let me know how this works out for you Mike
Feb 04, 2016 | Televison & Video
How to turn up the power on the midland 78 plus
Midland 78-574: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-976: {L7, L11, L13, RV12-AMC, RV2-ALC, RV11-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-999: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
I put these up due to not knowing which one you have
May 07, 2015 | Midland Radio Communications
Bike is not idling, wants to keep creeping while clutch is in and brake is on, had hard time today going into neutral
You're clutch cable needs to be adjusted. Most likely you can gain enough "pull" up at the hand lever. The adjustment will be turned clock wise, your goal is to imagine you're pulling the inside cable more-farther to dis engage the engine from the wheel. You should have a little play when the lever is at rest to be absolutely sure it's completely free. Might be worth a couple bucks to have a shop do it and ask to watch. It's a quick, easy adjustment but should have an experienced hand.
Jul 18, 2014 | 2011 Harley Davidson FLHRC Road King...
I have a cobra 29 ltd but have trouble maintaining any clear channels. Is there a way to maximize station clarity?
I just saw your message and the problems you have been having, from your description you have managed to get everything sorted out and working. I to have been into cb's for many years and enjoy the challenge tinkering with the system and I congradulate you on a job well done.
Feb 28, 2012 | Cobra 29 LTD CB Radio
I have a WBB4500E1WW washer that started to make noise when in the wash cycle. Could a bearing be going out or what should we be looking for?
http://applianceassistant.com/repair/sounds/ddWasher_noises.php pa 1schmidt, without hearing the sound it is hard to say. Here (above) is a wonderful link for strange sounds made by washers and the parts to check for them. Wonderful site as well.
I would bet that something is stuck in the pump and needs to be removed, but it could be several other things.
Hope you find this link helpful; if you need any further help, dont hesitate to contact me.
thanks,
Mike
Jul 19, 2011 | GE WBB4500EWW Top Load Washer
I have a galaxy dx 959 cb in my 2005 international.it will only reach about 3 trucks away from mine and can hear a little farther. what could be the problem? i have the wires connected as shown in manual...
What are the swr's on the antenna system. check that first.. It should be free to have it checked at any shop if not they are not honest. or they are money hungry...
squelch should be counter clockwise. ccw.
mic gain should be clockwise. cw
rf gain should be clockwise
Jan 22, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
PA squalls when mike pushed
Try running a temporary wire for grounding.
Tom
Jun 29, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Gain failure
If you are 'testing' the unit by holding the right button and pressing power, the pmax units really don’t work with the internal test. What you are seeing in the test is what th humminbird factory computer test used to test it. That is really not intended to be used outside of the plant. If it works fine in normal mode then I would say that the unit is fine.
Best of luck!
Mike
Jun 28, 2009 | Humminbird Piranhamax 220 Fishfinder
Error E68.
its probably a hard drice problem i dont think it will happen again if you get a new HDD unless its a piece of junk as well
May 18, 2009 | Microsoft Xbox 360 Console
Maxon HCB-10C CB Radio Logo
118 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
