Question about Frigidaire FRS26KW3AW Side by Side Refrigerator
Frigidaire FRS26KW3AW I think I'm going to have to replace the tubing coming in from the bottom of the fridge and connects to the water filter. How do I do this? Or should I call for service?
    Genius:
  • 1,122 Answers
Why do you think you have to change the tubing!!???mike
Posted on Jun 04, 2008
Frigidaire water dispenser drips constantly. I have been told there is a main water valve and a second valve for the water dispenser. Where is it and how to replace?
if you are referring to the cold water on the door , then there is a solenoid valve on the bottom back left side of fridge, you will see two there , one is for ice maker and one is for water on door , most times it's a good idea to replace both of them , also there should be a filter inside fridge on bottom middle (cartridge) this should be changed monthly to maintain fresh taste and keep foreign objects out of tubes
Jun 01, 2015 | Frigidaire Refrigerators
Water dispenser on Frigidaire FRS6R5E refrigerator is not working but ice maker is working fine.when i open the filter area & press the water dispenser button water comes out from that area & when i put in...
At the back cover of the fridge you will find a double electric valve. The easy way to find valve is to follow water supply tube to your fridge
Unplug fridge and check with multimeter if one of the coils burned out and should be replaced. Make sure you close water shut off valve before removing solenoid. Good luck
Nov 14, 2013 | Frigidaire FRS6R5E Stainless Steel Side by...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Freezer fan is making loud noise
Fan is hitting ice build up...defrost is bad...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 19, 2010 | Frigidaire FRS26KW3AW Side by Side...
SMOKE COMING FROM BACK OF FRIDGE, near bottom around compressor, I think
The overload / relay , is burning up . You need to replace it , as soon as possible , to keep the refrig cooling . Pt # 5304468029 .
Dec 10, 2009 | Frigidaire FRS26KW3AW Side by Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Dec 20, 2008 | Frigidaire FRS26R4A Side by Side...
Fridigidaire FRS6R5EMBD
i don't think it is dangerous but it could be water minerals that was not filtered by your filter. sediments that is in the water that have settled at the lower part of the tubing.. if you can replace the coils of tubing then it would be much better.
tnx 4 using fixya,
drcool
Nov 08, 2008 | Frigidaire FRS3R5EMB Side by Side...
HOW DO I CHANGE THE WATER TUBING?
you need to go to lowes and get whats called a double ended quick connect,cut a little piece of tubing off and take it with you,push tubing in on both ends,now run your door water dispenser till the water is clear,with icemaker on make a couple of tray s of ice,throw away,remove quick connect by pulling round tab in and pull tube out,install filter and your good to go,hope this helps,thanks-mike
Jun 01, 2008 | Frigidaire FRS26KW3AW Side by Side...
Frigidaire FRS26KW3AW Side by Side Refrigerator Logo
61 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
