Question about Sony Ericsson W300 Cellular Phone
Charging Problem At times my SE w300i cant be fully charged..... it flashes "OPTIMIZED CHARGING" repeatedly till the charger is switched off. I had similar problem with a Ericsson phone too, so it a software problem. Please help in this regards. Thanks
    Brigadier General:
  • 7,752 Answers
You can go to topsony.com sign up and have it reflash there for a fee this is a pay site...or take the phone to a mobile service center and have it reflash there.
Posted on Jul 05, 2008
Sony ericsson w300i charging eror
Dear Brother:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 08, 2012 | Sony Ericsson W200i Cellular Phone
Sony Ericsson W300i charging Problem when i connect a charger with My W300i but not charging... My Batery, Charging Socket, charger are o.k. pls solve my problem....instant
hii
In this problem there might be your charging socket is broken,
so you need to replace it and make sure that the repairing has done by an expert.
I hope you are satisfied/
Thanks and let me solve your further problem.
Aug 20, 2011 | Cell Phones
Sony ericsson w300i n stop charging solution
my sony ericsson W300i phone is not charging because when i connect charger phone not charging or any charging reaction......
my battery, charger, charging socket all are O.K. ..
pls send me urgently sollution.....for this on mail....
yoga.solanki@gmail.com
May 30, 2011 | Sony Ericsson W300 Cellular Phone
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
In sony w300i phone is charging erro probleb. so pleas can u give some solution?
First Option:
Secend Option:
Aug 17, 2010 | Cell Phones
I have problem with w850 charging when mobile
phone software is corrupt tutorial on how to flash new software to the phone here: http://forums.se-nse.net/topic/16148-tutorial-flashinggdfs-operationsuploading-files-with-xs/
May 18, 2010 | Sony Ericsson W850i Cellular Phone
I connect it and it appers charging-non-standard-battery
off the phone 4 some time and on it then charge,if no change, change ur charger if nothing happen change ur battery or check ur charging port
Apr 07, 2010 | Sony Ericsson Walkman® W610i Cellular...
Phone is in the charger and after charging for a little bit it stops charging and says "warning bad contact of charger" how do I fix this problem for nokia n97. Please help
Hi, the problem is with either the phone charger or the charging port IC.. First of all, change your charger and see if the problem will still repeat itself, if it does, then you have to take the phone to a phone technician to change the charging IC.....
Feb 25, 2010 | Nokia N97 Cell Phone
K850i charging problems and red light flashing at on/off key
Your battery is either not charged or the battery cell is completely gone.
I'll advice that you get another battery and give it a trial, also look out for the charging port. Check if it is not rust in any way because, if the charging port is rust, it will be difficult for the charger to contact the charging port.
I believe what's wrong with your phone is a minor fault, just do a thorough check and you will find a solution to the problem.
Best wishes.
Dec 04, 2009 | Sony Ericsson K850i Mobile Phone
My k550i shows, 'charging alien battery' some times i'm connecting to plug, some times it shows 'optimized charging'. wats d difference between these 2 messages.
The battery you are using is not of good quality.Alien battery actually is categorized as the lowest quality of compatible batteries, Optimized Charging refers to the advanced charging circuit in SE phones that prevents damage and ensures the battery is properly charged.
Jul 16, 2009 | Sony Ericsson K550i Cellular Phone
Sony Ericsson W300 Cellular Phone Logo
100 people viewed this question
Top Sony Ericsson Cell Phones Experts
Prashant  Sharma
Prashant Sharma
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
