Question about Hampton Bay Heating & Cooling
My hampton bay fan has a bad solid-state fan speed control model no. uc7067rk-there is also a no. on the side of it which is 7067kcb-62[4.5+5] which i' ve not been able to find anywhere. the fan is about 5 yrs. old
SOURCE: I'm selling a Hampton Bay
As long as you have the remote and the receiver that go in the top it will work
Posted on Jan 21, 2009
SOURCE: Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Posted on Apr 08, 2008
SOURCE: master control knob
I got a replacement master control knob from http://www.repairclinic.com, item number 868845.
Posted on Aug 06, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
bobotfel
  • 236 Answers
SOURCE: Remote operation of ceiling fan NOT working.
Try to check the remote control by using camera or cell camera, just use it as your eyes to see if the remote control emits signal. Just point your remote control to the camera and "on" then check if the remote control emits light, if no emitted lights means defective remote but if emit lights then the receiver is defective . Try also to locate if there are any reset or rst button on the remote control and press it then test.
Posted on Jan 10, 2009
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Remote-Wall-Controls/Hampton-Bay/N-5yc1vZbvmuZp4
Apr 03, 2017 | Hampton Bay Dryers
Fan speed control electrical box burned up in less than 60 days need to replace it. Model: UC7067RK
Most the time when I hear of a UC7067 "burning up" it usually means the person has a dimmer switch on the wall that is supplying power. You will need to replace the dimmer with a standard on/off toggle switch or add an in-wall remote where the dimmer switch currently is. Both the UC7067 and WC-210 Wall controllers can be found at http://www.fanmanlighting.com/default.asp
Hope this helps!
Jan 24, 2011 | Hampton Bay Dryers
Hampton bay fan model 761 567 running faster on
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The receiver is located in the upper portion of the housing for the fan motor. Look for a semi-circular black control box (usually manufactured by Rhine)
Jun 05, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I HAVE A HAMPTON BAY MODEL AC-418 CEILING FAN. IT
The fan unit itself is manufactured by AirCool 800-896-4908
May 10, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
https://www.hunker.com/12003281/how-does-a-ceiling-fan-speed-control-work
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
My Hampton Bay Windward II
I need a fan chain pull switch for my Hampton Bay 5 Blade Model 552 od--
SKU # 409-952----
MFG # 5A00007
SER # 720275940415653B
The switch controls High,Medium,Low Speed and Off.
4 Wires--Black,Brown Purple and Gray are connected to awitch, they come from a Block Capacitor (4.5mf,6mf and 5mf)
This fan was purchased around 1995 and is in good condition but needs this replacement switch---
Where can I get the replacement for this model?
Apr 19, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ponte Vecchio ceiling fan light flickers
Try swapping out the bulbs and see what happens. There are bulbs made specifically for ceiling fans that have heavier duty filaments in the bulbs, or you could use compact fluorescents. The warning about using a solid state control was referring to using a solid state dimmer at the wall switch.
Mar 01, 2009 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Jan 03, 2009 | Hampton Bay (261025) Dual Mount Ceiling...
No high speed on Hampton Bay Fan
The high speed motor winding may have opened. Not too common on Hampton Bay fans.
Jan 20, 2018 | Hampton Bay 52 In. Genoa II Fan, Crackle...
Hampton bay fan, wall mount remote control
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Heating & Cooling Logo
376 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
