Question about Frigidaire GLTF2940ES Front Load Washer
Fast spin not working and sometimes clothes sopping wet
    Sergeant:
    Champion:
  • 226 Answers
It can be a bad heat sensor
Posted on Oct 15, 2010
Maytag washer is sometimes out of balance and clothes are sopping wet when spin cycle ends. Washer is balanced on the floor.
1ST thing put less clothes in washer each time
second ck to see that drain hose is not obstructed from draining out the chamber , ive seen fabric lint get stuck inside the drain valves and slow and eventually block them off
last thing to look at
temp defeat the lid lock switch and or watch it spin thru window , your looking for the speed it spins at (should be a blur !!) , if its slow and not steady in rate but instead sort of gets slow/fast/slow/fast this could be an indication that your tub drive system isn't working well , this depends on a large bit of things working properly , but could be as simple as a worn out drive belt too.
Feb 03, 2017 | Maytag Washing Machines
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
Kenmore Automatic Washer Model 110.24642300 - problem is that spin cycle is not fast enough to get the water out, so clothing is sopping wet and loose at the bottom of the tub instead of plastered to the...
Your transmission is starting to go bad. It is not creating enough power to spin the clothes fast enough to dry them. It is cheaper to look for a new washer . To fix the transmission will cost you over 400 I would do light loads until your able to get a new washer
Jul 12, 2011 | Washing Machines
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Jun 24, 2009 | Kenmore 44072 Front Load Washer
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
