Question about Fujitsu 22U Air Conditioner
Where can i get remote for a samsung bio tech plus air con/heating unit?
Where is the reset button exactly on a samsung bio tech plus air conditioner? Will this also reset the remote ?
What are you exactly trying to reset?
There is a board under a cover on the right side of the indoor unit and two on the outdoor unit. usually there is a problem when the unit locks out. This is by design so further damage will be limited.
Jan 28, 2014 | Heating & Cooling
I have an Air-con air conditioner and heating system
Check your filter, if it's clean check the condensate drain to be sure it's draining if ok your system has a leak and will need an ac tech to repair and recharge the system
Nov 28, 2013 | Air Con 9,000 Btu Split ditioner Wall...
I have lost my manual for my bio tech plus air con. my air doesnt seem to be cold at all, not sure if i have right setting, on the remote there is a sun, snowflake auto and i think a raindrop, which should...
Dear friend, find below symbols for mode setting. For cool keep minimum 3 degree less than room temp and heat keep minimum 3 degree higher than room temp. Dry mode will help you only in wintertime. Thanks.
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Feb 01, 2011 | Heating & Cooling
Trying to locate a site to download manual for a samsung bio tech plus air con I have no manual
Samsung has product manuals on their website, free for the download, in PDF format. Click here,
http://www.samsung.com/us/support/#
select your appliance, select your model, and they'll take you to a page where you can download the owner's manual. Good luck, and rate my answer if it helped!
Jan 31, 2011 | Samsung Refrigerators
Lost remote for sfh8111 heater how do i turn on without it?
if there is not power on button anywere on the indoor unit. you will have to buy a new remote . you can get universal remotes for tvs that do air cons and heaters. try ringing tech support for the unit also.
Nov 09, 2010 | Heating & Cooling
Hi i have recently purchased an amcor sPLIT UNIT AND CAN NOT GET THE HEAT TO WORK AND DO YOU HAVER ANY SUGGESTIONS AND PRESUME IT IS A SETTING i AM NOT CORRECTLY PRESSING ? rEGARDS cRAIG
dear sir
please first make turn on your electrical supply for air con
and then use remote controller and find out there heat mode and select it then make your air con on heat mode ..
i hope it will work on heat mode
hope answer the question
thank you
please vote!
Sep 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Hello I have Sharp Air con/Heating AY-XPM9FR with a floor/wall unit and a higher wall unit that are supposed to work in conjunction with each other. I have never had any problems until we had a power cut...
Hi Helen, i want to know the age of your Sharp Air con/Heating system. If its more than 1 year and you using it regular basic , then i suggest you change the battery or the remote control first then try . If the same thing happens then follow the instruction as per below image.
If there is also ok & look good then ,please call a service man and check the air cooling/ heating gas. Because you mentioned "I have the manual and have tried to reset the timers using the remote control but still no good. " Another chance you can take before call the service person, just reset the full system by remote control not only the timer. Thanks & waiting for your feedback.
Feb 18, 2010 | Heating & Cooling
Lost Duracraft AMD8500E remote
I have one for the AMD8500E Air Cooler by Duracraft.
It is brand new £40 plus P&P on top.
Justin.kandiah@talk21.com
Sep 14, 2009 | Heating & Cooling
Brewer in dire need
this is gold, is strange to heard that one fails, but have to happen, dont leave regular people tuch it, get a good tech, it seems to have a sort problem, I know the compressor are ok becouse it have dobble protection, must be a capacitor problem..good luck
Aug 08, 2006 | DeLonghi Pinguino PAC-GSRU Air Conditioner
Fujitsu 22U Air Conditioner Logo
293 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
