Question about Dishwashers
I have standing water in the bottom of the dishwasher. Try to run the cycle several times, still the water is there. What can I do ?
  • Alf Hopkins
    Alf Hopkins Oct 15, 2010
    need brand and model.
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Oct 16, 2010
Why is there water standing in the bottom of my dishwasher after it has completed the wash and dry cycles.......
If water remains in the dishwasher after the cycles end, check the kitchen sink drain to make sure it's not clogged. If there's no clog, try pressing the Cancel button; most dishwashers run the drain pump when the Cancel button is pressed.
Check the dishwasher drain line, drain path and drain pump.
Oct 25, 2017 | Dishwashers
Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Standing water in bottom of dishwasher
The first thing to try is to clear out debris from strainer area, you may need a Philips head screw driver for this. Clear out and then attempt to put the unit through its cycle.
The second thing I would try, is unattach drain hose from drain to sink, either blow in it or use a blower side of shop vac to force air into the hose. Reset dishwasher, and try again.
Not knowing how handy you are, you can pull the dishwasher out, please turn off circuit before doing so, also make sure you have towels handy. Unattached drain hose at base of drainage pump. Clear out hose and remove debris on bottom of pump. Reattach the hose and run through cycle..
If these do not work your issue is with a bad pump.
If there is a
Oct 13, 2009 | Dishwashers
Tappan Dishwasher w/ Standing water
Try draino first then take it apart on the inside bottom to see what might be clogging it.
Aug 04, 2009 | Dishwashers
My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
Standing water in bottom of dishwasher...didn't drain.
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. Try to wash again after cleaning out the sudds and run it again. Thanks
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
