Question about Dishwashers
THE TOP SPRAYER DOES NOT SPIN. THE UPPER RACK DOES NOT GET WASHED
  • Alf Hopkins
    Alf Hopkins Oct 15, 2010
    Check that there is not particles of crud binding the top spray arm. Also make sure your getting enough water as low water level might cause not enough volume of water to get to the top. Also need brand to narrow any further.
  • Dishwashers Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101 .
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 16, 2010
Little water to top rack
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | GE Dishwashers
Dishwasher won,t clean dishes ontop rack
Make sure the top rack is pushed back all the way to connect with upper sprayer arm water port. Also make sure nothing is preventing either sprayer arm from rotating and there is nothing blocking the sprayer arm holes, like seeds or pieces of plastic debris. Also make sure your water heater temp is hot enough.
May 18, 2011 | Electrolux EIDW6305GS Builtin Dishwasher
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Frigidaire dishwasher doesn't seem to wash top rack. The dishes are oily with stuff dried on them. It worked for several years before this. I took out the sprayer and ran water thru it to make sure it...
Have you taken the tube that goes to the top sprayer off and washed that out as it may be clogged especially where the sprayer goes on it has a small opening.
Oct 27, 2009 | Frigidaire Dishwashers
Top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
Sep 02, 2009 | Whirlpool Dishwashers
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
Upper rack spinning device fails to aquire water and does not spin
Jeff, When a dishwasher acts like this, the most common problem is a blockage in the sump area, underneath the lower spray arm. Removing any/all filter and covers down there (screws will need to be removed) and inspecting with a flashlight, remove all debris (watch out for broken glass!)  Also, inspect the "impeller" that is turned by the wash motor for damage or being loose while you are down there.  Reassemble and test out.
If problems remain, the next most common problem is a failed wash motor.  It is common over the years for it to weaken as it heads towards total failure.  These motors, when they fail, can not be repaired, rather they must be replaced.
Please post back with what you find, OK?
Apr 14, 2009 | Kenmore 24 in. 16152 Built-in Dishwasher
Not enough water pressure to move upper arms or clean dishes
Recommend you pull the bottom spray arm straight up, then out of the DW.
Remove 9 phillips screws that hold the filter shroud down. Remove the filter and clean/rinse it out.
While the filter it out, grab a flashlight and inspect all over the sump area. Especilly in the area the has the check valve that rotates (Vario motor-driven) to feed the water pressure either to the lower and then the upper arms. Watch out for broken glass! Also, inspect the impeller to see if it is undamaged and spins easily.
Reassemble, then test out.
If problems remain, the the wash pump motor is probably the culprit. Do you get any error messages on the time display?
Good Luck!
Apr 05, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
