Back to:
Tags:
Home Theater Speakers and Subwoofers
Generic problem for all Home Theater Speakers and Subwoofers
Home Theater
posted by marcdi on Jun 02, 2008
My home came with pre-installed speakers for home theater, which are also in each room in the house and outside. For no apparent reason, half the speakers have stopped working. I have checked all the connections (I think), but cannot seem to find the cause of why some are working some are not.
Comment by marcdi, posted on Jun 02, 2008
The receiver is a NAD T-761 surround sound receiver; amplifiers are Harmon Kardon PA 4000. The interior speakers are also Harmon Kardon, and the exterior ones are Niles.
Meant to ask, is there an easy way to fix this problem?
Thanks, will take a look and email the info.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Abrsvcs
Rank:Guru Guru
Rating: 86%, 802 votes
There is most likelt a channel not working in either the receiver or amplifier depending upon what equipment you own. Could you update this with a list of the equipment in the system?
Thanks,
Dan
Comment by Abrsvcs, posted on Jun 02, 2008
We need to determine whether one of the amps has a problem or if the amp is not being feed a signal to amplify. Can you provide a simple stick diagram or description of what is connected to what? For example, the left pre-amp out from the NAD761 is connected to HK amp #1 left. With that info, I'll give you a process to isolate the problem equipment. Then we can determine how to fix that piece.
Dan
Rating Locked! (?) marcdi has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Home Theater:
I don't want to Accept this solution
Can you Help with these Home Theater Speakers and Subwoofers problems?
I have a krk submonitor that I use with my av reciever and...
JBL EON 15-G2 Powered DJ Speaker With EQ...
We are a 5 piece classic cover band and use 2 eon g2's...
Durabrand HT-3915 System
How dose this system detect 5.1 when it only has L&R...
Altec Lansing VS4121 Speaker
i want to but a good speaker system 4 my laptop and...
Boston Acoustics MicroMedia Speaker
when i hooked my boston speakers to my windows vista the...
Loading problems.
Repair Service
Find Home Theater Spe. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
