Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi rear projection tv
I have a rear projection hd wide screen tv that is 7 yrs old.The tv was working fine untill I sold it to a friend,when he got it home he plugged it in and turned it on,The green on light would turn on then off everytime you would try to turn it on. He brought the tv back now the green lights up and stays on when you turn it on,but still no picture.
  • Amy Jul 18, 2008
    Same thing is going on with mine only my light isnt on. It just shuts off as fast as its turned on. Can someone help me?
  • 927 Answers
Good Day, xraykid;
The problem with the TV is that it's mad at you for selling it to another family and now it's only sad once the TV came home. What you need to do is to talk to it for several weeks..............
Just joking, but the problem with the TV according to garth is:
SHUTDOWN AT POWER Cause #1 This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. The real problem may be fluid from the crt's, picture tubes, look for fluid on the PCB towards the front of chassis.
Good Luck, big IRISH, e me first, then will help via phone,, Iwant to help you , that happened to me b4.
Posted on Jul 15, 2008
How do i get the front screen off of a 46 inch zenith rear projection tv. it's 13 or 14 yrs old
First, unplug the unit.
Then remove the speaker grills. At the bottom of the screen there should be approximately 8 -10 +/- screws. Remove these screws and the screen should lift right off. Before unhooking the screen at the top, be sure to check that no sensors are attached to screen assembly and have a friend hold the screen while you unhook the two connector plugs that go into the back of the screen.
Jan 17, 2010 | JVC HD-61Z786 61" Rear Projection HDTV
resolder the convergence ICs . Common problem with mitsubishi rear projections
Jun 16, 2009 | Mitsubishi WS-55859 55" Rear Projection...
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Picture doesn't fit screen
If you haven't tried to change the format yet, try that first. Most of these tv's have a wide range of options from full to wide to split etc. Stretch would probably work in most hd formats.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Problems with my Mitsubishi hd1080
Most likely you are looking at conversion chip problem. The replacement price on these can varry widely. It may be cheeper to look into purchasing a flat panel lcd or plasma tv.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi projection TV WS - 55413
any flashing LED's when running service mode or convergence signal?
Apr 27, 2008 | Mitsubishi WS-55513 55" Rear Projection...
you need to do self test first look in threads and also to get error codes.
Dec 30, 2007 | Mitsubishi VS-50611 50" Rear Projection...
Mitsubishi WS-55311, 4 yrs old, flashing screen on all inputs
First thing to try is to press the reset button on the front of the TV. This forces a system reset.
Feb 03, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
