Question about Roper Washing Machines
I have a roper washing machine model # lsq8520jq1 and recently when the machine turns on it fills with water and the bowl starts slamming agianst the front and back of the washer and i have no clue why
    Sergeant:
    Champion:
  • 226 Answers
Sound like the balance is off or springs is broke
Posted on Oct 15, 2010
ROPER WASHING WONT FILL WITH WATER IT WILL GO THROUGH CYCLES BUT WONT FILL WITH WATER.
Without a model #, it's hard to say. My 1st guess would be the water valve either bad or screens stopped up.
Sep 03, 2017 | Roper Washing Machines
Rinse cycle only fills halfway
alot of newer machines do that. water saving feature
Dec 04, 2015 | Roper Washing Machines
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Have a Roper Model RAS7133RQ1 washer turns on won't wash etc
hi there i think the problem is that your big end has blown and this is affecting your gangle pin you will need to replace these and these are very cheap and available from any hardware shop your friend MR FIXIT
Apr 26, 2009 | Roper Washing Machines
Roper washer fills with water continuously
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares'
Feb 23, 2009 | Roper RAS8445KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Wont fill up with water it drains out before its full
If you hear the motor running when it is draining then you have a bad timer. If it just drains out and the motor is not running then you have a siphon problem which is caused if the drain hose is too low. Let me know what you find.
Dec 03, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
