I AM WRITING THIS ON MY PRIMARY COMPUTER OR THE HOST COMPUTER. I WOULD LIKE TO SHARE THE PRINTER ON THIS COMPUTER WITH A LAPTOP THAT I HAVE CONNECTED TO THIS COMPUTERS NETWORK.
  • 4 more comments
  • tomyun Oct 17, 2010
    this is the computer that the printer is connected to.
    I AM HAVING A PROBLEM FINDING A SOLUTION TO THE PROBLEM LISTED ABOVE.
  • tomyun Oct 18, 2010
    the ccomputer i am writing on now is the main computer and has the printer connected to it. my laptop is networked to this computer and i am trying to get the laptop to use this computer.
  • tomyun Oct 19, 2010
    I AM WRITING THIS ON MY PRIMARY COMPUTER WHICH IS A DESKTOP. I HAVE A PRINTER CONNECTED TO THIS COMPUTER. I ALSO HAVE A LAPTOP NETWORKED TO THIS COMPUTER. WHAT I WANT TO DO IS TO USE THE DESKTOP PRINTER TO PRINT THINGS USING MY LAPTOP.SO HOW CAN I MAKE THIS CONNECTION?
    MY PRIMARY COMPUTER HAS WINDOWS 7 AS THE OPERATING SYSTEM. MY LAPTOP HAS WINDOWS XP AS ITS OPERATING SYSTEM. THEREFORE YOUR SOLUTION DOES NOT WORK IN THIS SITUATION.
  • tomyun Oct 20, 2010
    I HAVE READ YOUR SOLUTION. THE ONLY PROBLEM IS THAT MY PRIMARY COMPUTER HAS WINDOWS 7 AS THE OPERATING SYSTEM AND NOT WINDOWS VISTA. MY LAPTOP DOES HAVE WINDOWS XP. SO PLEASE TAKE THIS INTO CONSIDERATION.
  • 4,737 Answers
To print documents from your Laptop (client), you need to share the Printer from the Desktop (server) and it's also important to note that, you'll need drivers for XP, since the client's Operating System in windows XP. The only thing you need to mainly set-up is on your Vista Computer.
First open the network card's properties and verify that the "File and Printer Sharing for Microsoft Network" is enabled.
After the settings is verified/changed and saved, open the "Network and Sharing Center"
[I hope both the computers are connected as Local Area Network (LAN)]
Once it's opened, click the "Private Network", then scroll down to the window and locate "Turn On Printer Sharing", and click it and then "Apply"
Now open the "Printers and Faxes" folder, right click the to be shared printer, select "Sharing"
A new windows "Printer PropertieI AM WRITING THIS ON - dc0c7ca.jpg open up.
Now click "Change Sharing Options" and aI AM WRITING THIS ON - 2d289b7.jpg the "Share this printer"
Again click "I AM WRITING THIS ON - 89da2af.jpgal Drivers
", you'll see something similar to this :
If something is selected, don't deselect anything, simply select "Intel Windows 2000 or XP" and then click "Ok", you will be asked to insert the Printer's disk, or may not be since vista's driver comes with the xp dirver packed. If you are asked, insert the disk and follow the onscreen instructions. Once it's done, close all the wI AM WRITING THIS ON - 3930b8f.jpgcheck whether the printer has "Shared" icon or not. (looks two people)
All this is to be done while the printer is On.
Now on the windows XP, click "Start", then "Run" and type in \\computername (the name of the vista computer, if you are not sure about the computer name, right-click, My computer - [on vista], "Properties" aI AM WRITING THIS ON - 8488d39.gifcomputer name)
Pointed and circled (This is to be obtained from the Windows Vista computer):
Once you press enter after typing in \\computername, the shared folders and printer will be opened up, by default there are few folders already shared i.e. My Shared documents..
That's all, you are done and your printer is share from the Windows Vista computer to the Windows xp computer.
[Note that both the computers Locally connected, if only ICS (Internet connection sharing is enabled), you may find some problem, in that case, check the "Worgroup" on both the computer and set a common name, eg, set "HOME" or whatever you like... ]
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 20, 2010
  • Lebanon Raingam
    Lebanon Raingam Oct 20, 2010
    Oh.. so sorry... it's my mistake.. I thought it was windows vista, please give me another few minutes, I will update you within an hour. Thanks.
  • Lebanon Raingam
    Here's a tutorial for you (windows 7 printer sharing), If you have any problem, let me know.
    Good luck.
  • 656 Answers
Thease are the procedures to share a pc or laptop to printer
To open the Printers and Faxes folder
Click Start and then click Control Panel.
Click Printers and Other Hardware, and then click Printers and Faxes.
In the Printers and Faxes folder, I clicked the printer's icon and, in the tasks pane, I clicked Share This Printer.
I opened the printer's Properties dialog box, and clicked on the Sharing tab.
I clicked Share Name, and then clicked OK.
That's it-the printer was immediately available for other computers to use.
Now that I had a network printer, I was ready to connect to it and print from other computers on the network.
To connect to the printer
I opened Control Panel, and clicked Printers and Other Hardware.
I clicked Add a Printer.
Instead of adding a local printer, though, I clicked Printer Connection and then browsed the network for the printer.
The whole process took less than a minute before I was printing to the network printer as though it was connected to the computer.
if you need further assistance please sent a reply
Posted on Oct 19, 2010
    Genius:
  • 1,035 Answers
Hi. May i know if this is the computer where your printer is connected?
Posted on Oct 15, 2010
  • Angelito Rabago
    Angelito Rabago Oct 20, 2010
    Hi. Can we do a remote sesion? this case is not a simple issue. We need to access your computer from our end for us to verify what is causing the problem.
  • Angelito Rabago
    using Two operating system is not a problem. Just tell me if its ok with your to do remote session?
Desktop computer windows xp...sons laptop windows 7 ..wireless router....same internete signal...can his laptop find my printer..or do i need to run same cd on my sons laptop..to get it to install on...
Yes it is possible, you have to install the pritner software on your Sons laptop.
1) For sharing, if you have a network printer connected to your router, then select the network option while installing the printer (If you would have given us the printer model and make we could have given step by step instructions).
2) If the printer is connected to your XP computer and you want to share it, share the printer from XP as mentioned in the steps below.
>> Open Printers and Faxes. Click Start, click Control Panel, click Printers and Other Hardware, and then click Printers and Faxes.
>> Right-click the printer you want to share, and then click Sharing.
>> On the Sharing tab, click Share this printer and then type a share name for the shared printer (e.g. MyPrinter), click on Apply and Ok. (as shown below)
Now goto the Windows 7 laptop and follow the steps as mentioned below,
>> Click Start >> Click on Devices and Printers >> Click on Add Printer (as shown below)
>> A new window will come up, click on Add a network printer (as shown below)
>> The laptop will search the network for the printer and display it on the list, click on the printer and click on next. The laptop will install the software required, do ensure the printer installation disc is in the laptop in case if Windows 7 wont have the driver it will take it from the disc.
Regards,
Shrey
Jun 03, 2011 | Office Equipment & Supplies
Have a laptop connecting to the internet via netgear WGR614 router. I would like to host my dell 942 connected to my dell demension 3000 so my laptop can print
What you need to do on the host computer is SHARE the printer. You may need to reset sharing permissions, and if you have NORTON, you need to turn lots of stuff off, or the printer will never show.
Mar 13, 2011 | Dell Office Equipment & Supplies
Can i set up my photosmart c5280 printer to print wirelessly from multiple computers via my router
Yes, you can. The easiest (and most secure) way to do this is to share it through a computer that is always on as the printer's host. Actually, looking at the specifications of the C5280, it is your only option. On the host computer (the one directly connected to the printer), click
(On Vista) Start > Control Panel > Printers
Right-click on the printer you wish to share, then left click on Sharing ... and click the checkmark box for "Share This Printer As" and give the printer a name. If this option is grayed out, click the shielded button Sharing Options and enable printer sharing.
On each of the computers you want to have printer access, open the printers window (see above) and double click the "Add Computer" icon. From the dialogue box, click "Add network, wireless or Bluetooth Printer." Your shared printer should appear on the list. Follow the prompts to install the printer, and you are ready to go!
Notes: The process is almost identical for WinXP and Windows 7 with small variations. Printer drivers will probably not be necessary, the remote computers may ask for one. Install the driver on each system as requested. Opening printer sharing can cause security vulnerabilities on improperly setup routers -- make sure that your wireless router is properly secured with WPA2 encryption and a security key (built-in features on most routers, but usually turned off by default).
Oct 16, 2010 | HP Photosmart C5280 Printer
Our HP desktop and Dell laptop are both connected to a AT&T 2 wire router/modem. The desktop is connected to an Epson non-wireless printer. How can we print wireless from the laptop? The laptop is...
You have to install the relevant drivers FIRST (Just install without printer thats fine) on the host & clients and then make sure you "Share" the printer on the Host setup. (The one where the printer is attached). Then on the clients you install a "Networked" printer and "Find" it on the network. Now ALL the PC's need to be in same"Workgroup" and have "Sharing" enabled on each machine, they all must have a name & password too..
Jan 30, 2010 | Epson Stylus CX9400Fax InkJet Photo...
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
http://www.microsoft.com/windowsxp/using/networking/expert/crawford_02april22.mspx
Oct 27, 2009 | Computers & Internet
I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Jul 22, 2009 | Computers & Internet
Want to share 922all in one on xp desktop with laptop using Vista
I have a network running both an XP computer & a Vista computer. What I had to do after connecting them both to the router was make an internet connection with 1 computer, turn on the printer so everything the network was going to share was powered on; then run the network wizard on both computers. Once I did this the computer that the printer is not physically connected to installed the printer driver. Once this entire process was completed we had internet on both computers as well as both computers being able to send jobs to the same printer. Has worked great for over a year. Hope this helps you out.
Mar 16, 2009 | Dell 922 All-In-One InkJet Printer
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
HP Officejet Pro L7580
Thats not true sir.
I was in HP as tech support and i have helped many customers in networking the Printers between different OS.
Thanks
Riz
(jack_36623@yahoo.com)
Mar 13, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
