Question about Whirlpool Dryers
Automatic cycle willnot work on dryer - Whirlpool Dryers
  • 618 Answers
Check to see if clothes are extremely hot during cycle if they are then the cycling thermostat is not opening . I take it it works in timed dry?
Posted on Oct 15, 2010
Front door willnot stay closed
Hello Shirelle,
The door lock mechanism is defective Or the door seal is seating properly.
Jul 04, 2015 | Whirlpool Cabrio WED5500X 27" Front-Load...
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
Dryer knob willnot advance back to off position on left side of timmer. I allready changed the timmer. But did not help.
Check and see if you wired it correctly. This is odd though. The timer actually engages the current and creates a continuous circuit until cycle is finished. There may be a physical obstruction keeping the knob in place. Check all this out and if still no luck , let me know and we will dig deeper.
Mar 11, 2013 | Dryers
Heaqt willnot work
The list of suspects usually invovles the heating element, the limit mounted on the heating element, the circuit breaker. The motor is a 120 volt one but the heater needs 240 volts. If the breaker is partially tripped the dryer could run but havee no heat. If the dryer cord id partially out of the recepticle the heat will not work. Make sure the dryer is getting 240 volts. Videos and more are here on my page
Mar 06, 2012 | Whirlpool Dryers
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
General Electric Heavy Duty Dryer willnot start when start button
WARNING: High Voltage may bzzt you... careful.
Your dryer thinks that it is at the end of a dry cycle.
First thing to do is disconect the dryer from the 220v mains and let it sit for about 10 min.
then, spin the timer four or five times around and then stop it at a TIMED dry cycle, not an automatic cycle. (example: 60 minutes).
Plug unit back into the wall.
SLAM door on unit and press button again...
Mar 12, 2009 | Dryers
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
Older whirlpool dryer gets too hot when using automatic setting
After 25 years,your automatic sensor may be bad. RepairClinic.com might have one. Clean everything inside while you're there.
Nov 26, 2008 | Dryers
Dryers Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
