Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
The spring for the door of my kitchenchaid KUDS01FL is broken and the door is now very heavy. Can someone point me to the correct part number and (if possible) instructions to change the part. Thanks! Frank
  • daube1 Oct 16, 2010
    Silverdragon, thanks for the info. However I cannot get the service manual on the link above - there is no place to pay on the page and they do not seem to recognize my serial number. Any other source to get the manual and hence the part number ? Frank
    Silverdragon, thanks for the info. I cannot get to the repair manual and hence the part number - my serial number not recognized (strange) and no place to pay on the page. Any other source ? Frank
  • KitchenAid Master
  • 12,061 Answers
Http://www.computercrowd.com/Itm250479242766_60270_KitchenAid_Dishwasher_Service_Repair_Manual.aspx
Above is your service and repair manual, this will show you how to do everything with your unit. Below, is a parts supplier, the ONLY place you can get the part number from the service manual.
http://www.kitchenaidparts.co.uk/
Below is a tutorial about how to replace the springs.
http://www.ehow.com/how_6674347_replacing-kitchenaid-dishwasher-door-spring.html
Posted on Oct 15, 2010
When i change my drive belt it gets shreded on start up
Sounds like either the belt is not tight or more likely your door balance is heavy ie fatigued/broken springs or its hung up somewhere.
Apr 16, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
Samsung microwave door popped open and now won't close. What happened?
The spring attachment to the moving latch has broken off either replace the latch or drill a small hole in the latch body and attach some heavy steel wire to make a new attach point for the spring. the inside trim easily pops off and the latch just slides off.
Jan 26, 2011 | Samsung Microwave Ovens
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
I cant get the interior fuel compartment lever to release. Any ideas how to open the door so i can get to the gas cap, without tearing the door off.
have someone use something to pry it open while you pull on the lever it looks like the spring is broken or rusted off. in case you have a broken cable you can remove cable from inside trunk.
Jan 09, 2010 | 1998 Saturn SL
I opened teh door and thought i felt something hit
Murray, It sounds like one of the door springs has broken and that is why the door seems heavier and opens with much more force.
You'll want to at least make a temporary repair and order a new replacment spring to get your dishwasher working like it should and so it's safer too.
You can check to see which side of the dishwasher the spring broke, by locking the door shut (with the cycle set to "off"). Now remove the lower access panel, beneath the main dishwasher door. There are a couple of screws near the top corner edges of the panel, just under the main door and a couple more on the toe kick near the very bottom.
Once you've got the lower access panel off, you'll be able to see the two door springs, (there is one on each side). Of course, the broken one might have fallen off the spring notches, so look around and you should see it.
With the door still closed and locked, you can remove the broken spring and see if it's just the hook end that broke. If that's the case, you can reform the end hook using a couple pairs of pliers and reinstall the spring on the door and frame mounting points. You'll have to use pliers to stretch the spring slightly to get it on the other mounting point, once you've got one end on a mounting point. If the spring broke off more than 3 coils, you'll need to replace it with a new one.
You can find a replacement by using searspartsdirect.com and putting in your model number to locate a line drawing and parts listing for your particular model. You can also order a new one from them, or use the part number to get one locally, if you wish.
Once you've got the spring back on the door and cabinet mount points, you can unlock the door and gently lower the door to see if everything is working properly. Once you've opened and closed the door several times, you can reinstall the lower access panel and you're back in business.
I hope you find this Very Helpful and best regards!
Oct 24, 2009 | KitchenAid Dishwashers
KitchenAid KUDS01FL - door spring tensioner snapped - how do I fix / get parts?
Replaced the tension spring cords. The plastic portion of the cords had broken. I think this is desined to fail since it is such light plastic.
Aug 14, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Broken door spring?
Either a spring or a door cable. On newer Kitchenaids and Whirlpools, it is usually a "cable" made of rope and plastic that breaks, not the spring itself. Get me the complete model number and I will look it up for you...
Dec 14, 2008 | Dishwashers
Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Broken Door Spring
hi you can do it if you have good hands open the cover side of the broken arm with the spirngs understand how the Mechanism works (in\out) and what went worng and hopefuly fix it or replace the springs that died good luck
Mar 23, 2006 | GE 24 in. GSD500X Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
240 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
