Question about Brother CS6000i Computerized Sewing Machine
I bought brother 5000 three weeks ago. I put the feed dogs down and now they will not got back up. It's almost like the feed dog switch is stuck on somethng. Naything I can do?
    Genius:
  • 1,788 Answers
Have you turned the handwheel at least 2 revolutions toward you after to put the feed dogs up?
Posted on Oct 15, 2010
  • Franc41 Nov 29, 2010
    Yes this was helpful to me!! - Thanks! feed dog button dropped the feed but would not return it to the up position so was impossible to sew! -Have tried this fix and seems to be working - I'm not dropping it again! Very New Machine - Brother Innov -iS 600
Feed dogs up?
If the feed dog lever does not raise the feed dogs, then they are probably stuck. Probably needs lubrication. Since the make/model was not specified, would recommend taking it for service.
May 11, 2016 | Sewing Machines
Feed Dog is not working?
Not sure if this model has a Feed Dog switch. May be located in area covered by storage portion of sewing bed. May be located on back side of freearm area will be indicated by multiple triangles near the switch.
Cheers,
Kelly
San Diego, CA
Embroidery Services
May 11, 2014 | Brother XL-3500
My feed dogs keep coming up when using a hoop doing embroidery what can be the cause?
sounds like there is something wrong with the feed dogs or the feed
dog lever could be broken,, they need to be checked
Jan 24, 2013 | Brother InnovIs 4000D Computerized Sewing...
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Aug 28, 2012 | Brother PC-420
My feed dogs will not come up into position
Some machines have to take a stitch for the mechanism to "pop" back into place, I don't really know if your brother is like that but try to sew with it and see if they click back into place.
Oct 22, 2009 | Brother Sewing Machines
Feed dogs stuck in down position
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
Sep 19, 2009 | Brother SE-270D Computerized Sewing...
that the feed dog lever is in the up position. When the lever is in the down position, the feed dogs will show on the top if there is no pressure on them at all. Make sure that the machine makes one complete cycle to check this. Just throwing the switch does not make them come to the surface.
If this does not work, then the feed gear is broken and you will need to take it to a mechanic.
Aug 26, 2009 | Brother SE-270D Computerized Sewing...
Feed Dog on Brother 270d stuck in up position
I finally figured this out. The feed dog switch in the back was not hitting anything when I moved it back and forth. There is a screw on the underside of the machine that I tightened. It seemed to do the trick. Thanks.
Jan 14, 2009 | Brother SE-270D Computerized Sewing...
Feed dogs are down
You might have the machine on a setting that does not use the feed dog. Check your stitch setting and see if that helps.
Dec 12, 2008 | Brother XL-2610
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Brother CS6000i Computerized Sewing Machine Logo
159 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
