I have a brand new Acer Inspire 7741Z laptop and it won't charge. I bought a new battery and tested my power cord, and they are fine. When plugged in, it reads "Plugged in, not charging." What do I do?
    Guru:
  • 1,481 Answers
As u say it's new use the warantee period to get it fixed from Acer
Posted on Oct 15, 2010
Acer m5-581t-6807 ultrabook won't power on
Disconnect power cord. Please disconnect battery. Hold down power button for a minute. Connect power cord only. Restart it.
Jun 24, 2013 | Computers & Internet
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
I have an Acer Aspire 7741Z-5731. I've had it for
If you changed your laptop battery and charger now nothing left to change. It could be problem related to you laptop motherboard.
On your laptop battery charging section not working properly. you can check you your laptop motherboard.
Jun 16, 2012 | Computers & Internet
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
The current factory battery in my laptop won't charge.
Please provide your laptop's brand and model. Still, there are some things you can try regardless of the brand:
1. Look whether your charging adapter lights on. If you have a voltmeter, you can simply check on the input jack. Testing with a friend's adapter from exactly the same laptop is another option, or at least check the voltage, polarity, power output and do not force the laptop plug. If your adapter is not working, test with a new power cord (from the wall outlet to the adapter). If this does not help, you will need a new adapter (fixing the old one is complicated and not worth it). An equivalent one can be easily found online, on the laptop's manufacturer's site or another one.
2. If the adapter is working, then the issue is probably with the laptop. If you have a second such laptop nearby, switch the batteries for a test (turn off both laptops before removal).
3. If the battery is fine, then most probably it is the laptop's plug, especially if the charging cable stays loose. This will require opening the machine and some skills, probably with the soldering iron. Better leave it to a specialized service.
Please let me know if the above was helpful.
Aug 08, 2011 | Computers & Internet
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Battery not charging. Computer is brand new. Works fine when plugged in, however icon below reads 0% charge available, plugged in, not charging''. I took the battery out and reinserted it, and still no...
If the Acer is brand new then it is under warranty. Take it back to where you bought the Acer and get it fixed under warranty. if you attempt to fix it yourself you will most likely void your warranty.
Dec 26, 2009 | Acer Aspire 5535-5050 Notebook
Acer aspire 4920g charging mechanism failed
Have you tested the adapter to see if there is any power getting to your notebook period. Use a multimeter to check for DV voltage. If you can't get your multimeter probe into the middle of the plug then I use a paper click to get in there. If your adapter is not supplying any voltage then there is a problem with it. I get a replacement adapter for my wife's Acer on eBay for about $30. Just search eBay for 4920g and you should get quite a few hits for the ac adapter or power cord.
If the adapter is providing power then the motherboard in your notebook is faulty since you've already replaced the battery. A replacement motherboard might be available from eBay. Replacing the motherboard could be complicated depending on your experience so I would leave that up to a notebook technician. An Acer certified shop may also be able to sell you a replacement motherboard.
I don't think it's the motherboard, my money is on the adapter. Test it out or have it tested.
Aug 28, 2008 | Computers & Internet
Acer aspire 3500 wont hold charge or turn on
remove the battery and see it the power comes on, if so bad battery, check the connector where the power plugs into the laptop, sometime this breaks or has a cold solder joint, you can test this by wiggling and looking to see if the power lights up. last and worst case is a bad main board.
Jan 07, 2008 | Acer Aspire 3100-1405 Notebook
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
