Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
When threading the bobbin the manual says to thread the bobbin through point a and then to thread it through point b until you hear a click - there is no waqy to thread the bobbin through point b - trying to just breaks the thread. I started with an embroidery thread and then went to a heavier thread - but no way to get the thread through point b - could there be a defect in my machine?
  • apcbink Jun 02, 2008
    I don't feel that I should have to pay anything to make my new machine work. I keep getting the E1 message. There is no way to make the b threading guide to "click". It is not just me - my husband tried too - there is no way to get the thread through B
    Please let me know if there is a problem with my machine - should I return it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. While threading the top part you’ll need to pull the thread back and forth in the top thread guide and check the tail in front is not curly. If still the issue persists, then it means that the machine has a bad thread sensor on it and needs to be replaced. In this case you can return the machine and get a new one instead to take the gain of the warrantee.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Dec 15, 2009
Bought machine at a garage sale. It works but no Manuel of instructions. Need to know how to thread it.
If you can't download the manual, try putting the thread on the spool holder with the thread coming off the spool toward the back of the machine. Be sure your fly wheel is turned toward you until the need is in its highest position. With the end of the thread, work your way across the top of the machine to the left, staying toward the back of the machine, threading through any thread guides as you go. There may only be one. Bring the thread toward the front of the machine and through the thread guide at the top front of the machine, then down on the right side of the tension knob and back up to the needle carrier. Then pull the thread down through any thread guides until you get to the needle. Thread the needle and pull the tail of thread to the back of your machine. Load your bobbin into the bobbin case, insert the case into the machine until you hear a click (you may need to rotate the case slightly to get it into the machine.) turn your fly wheel toward you while holding that top thread toward the back of the machine until the bobbin thread comes up. Pull the bobbin thread up and to the back of the machine an you are ready to go! Good luck!
Jul 22, 2014 | Sewing Machines
Elna tavaro
Could be a host of things to trouble shoot,
Needle, is it sharp and right size for fabric type? Sharp for woven or ball point for knit
Is threading up correct, you don't say which model but this is link to threading a Star Series SU
http://youtu.be/xEn3dNeiTqs
Is bobbin wound nice and smoothly, also should be Elna 7hole bobbin which is slightly dished and holes one side. Always wind with holes on top and load same way, when you draw thread off bobbin will rotate anticlockwise. Also check bobbin thread has clicked into tension spring. You will hear it click in. If you lift upwards and thread comes free then try again, push down on thread with finger tip till it clicks into spring.
Is top tension dial clean between discs, always thread with presser foot raised so thread goes into tension fully. Is thread in take up lever, and through all thread guides?
Top tension dial on 5
That's my regular trouble shooting list, hope it helps or add more details
Apr 18, 2014 | Elna Sewing Machines
How do I thread my elna super sewing machine
Hi Marsha, this is pretty straight forward on these beaut Swiss made machines.
Have you managed to wind a bobbin firstly? You need to disenage the clutch by holding the outside of the flywheel and turning the inner coupling knob towards you. Bring up the bobbin winder spindle into a vertical position. Place spool of thread onto one of the spool pins at the rear of the machine, then take the thread from your spool across to the thread guide on the left of the head of the machine, to the inside of the bobbin pull the tail from inside the bobbin up through a hole on top. Place the bobbin on the spindle and TURN IT SLIGHLY UNTIL IT CAN BE PRESSED ALL THE WAY DOWN. While holding the protuding end of the thread wind a few turns of thread on the bobbin by pressing the knee control lever until the core of the bobbin is covered securing your starting point. Stop and trim the loose end of thread up against the bobbin, then restart winding until it stops automatically when full, while keeping light tension onto your thread spool at the back (use the curved handle of your scissors into the top of the spoool) so it maintains even tension on the thread as it comes off. Watch the bobbin and give the thread a nudge with your finger if it starts to fill too much in the middle, you want a nice even wind top middle and bottom. When bobbin is fully wound, remove it and swing the bobbin winder spindle to the side. Then tighten up clutch again by holding flywheel and turning inner coupling wheel away from you until it is firm.
Open the bobbin cover flap, drop the bobbin in with the holes on top. Hold the thread tail and move it clockwise around the bobbin case until it goes into the little groove - press down on the thread while holding the bobbin still with a finger, you will hear the thread click into the tension spring. Try again if this doesn't happen, you must get it into the tension. You can test by lifting the thread vertically, it will come out again if not in the spring.
Now, top thread. Turn the flywheel toward you until thread take up lever is in its highest position and raise the pressure foot. Place the thread spool on a spool pin so that the thread unwinds itself from the side nearest the machine. Pas the thread from below throu the thread guide then throu one of the two openings of the upper thread tension, thread from left to right, through the hole of the thread take up lever, then pas it from behind through the two thread guides at the lower front of the head. Then thread the needle from front to back. Use the top thread to draw up the bobbin thread by holding the top thread and turning the flywheel towards you through one sequence so the hook catches the upper thread, then pull the top thread to draw up the bobbin thread to the top. Close the bobbin cov er plate, draw both threads to the back of the sewing platform and you're ready to sew.
You need to oil this vintage machine and there should be marked red points inside the head cover and on the side of the bobbin case denoting where.
I would suggest that you join the Yahoo group called Elna Heirlooms; you'll find some useful information there and very helpful members who maintain their Elnas like your model.
Oct 19, 2011 | Elna 2007 Mechanical Sewing Machine
How do you put a bobbin in a elna so i can use it to sew
Drop in a full bobbin with the holes side upwards (I'm assuming this is a Swiss Elna sewing Machine horizontal bobbin design as you haven't given the model number).
Now, hold the thread tail with your right hand and pulll the thread clockwise towards you while holding the bobbin still with a finger from your left hand. Bring the thread tail around towards you until it goes into the little slot, then press downwards onto the thread tail close to the bobbin until you hear it click into the tension spring. Test by lifting the thread tail upwards, it should stay in tension and not come back out of the groove.
Now close the back slide cover over the bobbin leaving the bobbin thread tail visible out to the right.
Now manually turn the flywheel towards you while holding the top thread tail and take the needle down into the bobbin holder area and back to the top, pull the thread tail to bring the bobbin thread up to the top.
There is a threading up diagrams at www.sewusa.com http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
for the old Supermatic but the bobbin holder design is almost identical for all the subsequent models such as the SU, TSP, Supermatic or Air Electronics like the Stella, Carina or Jubilee, the above is the same for all.
Sep 19, 2011 | Elna Sewing Machines
Elna 2007 sewing machine breaking upper thread in bobbin unit. It will be going along fine then the thread will snap. thread tension on 1. zigzag stitch. Thread passing through upper machine OK, but...
Is your top thread tension on 1? this sounds way too loose, should be 4 or 5.
This is a horizontal top loading bobbin machine isn't it like the Janomes?
Do you have a manual for it? It sounds to me like the top thread is too loose and as it is pulled down and around the rotary hook there is no tension on it to pull it back up through the fabric and form a stitch which is then causing it to jam. Then once youve gots bits of thread in there, its just jamming and jamming. Cleaning out the bobbin holder as you described is good, you may need to do it again and ensure all bits of thread are out of it.
I think you need to revist all the threading up and ensure that the top thread is under tension, try number 5. Also check that bobbin is correctly wound nice and smoothly, then loaded into the bobbin holder correctly so that the thread is coming off the bobbin spool in the right direction, ie thread needs to come off the bobbin, then reverse direction in a "v" shape, usually in the direction of the back of the free arm. And that the thread has been clicked into the tension spring fully, put the thread into the slot of the tension device and press down on it with your finger tip until you hear it click into tension.
Also double check the take up lever, if the thread has slipped out of this, it will jam up for sure.
If you don't have any manual for this then try www.sewusa.com, there is good troubleshooting tips and threading diagrams for lots of makes and models.
Hope this helps you, persever, its most likely threading/tension issues and can be overcome with the right settings.
Aug 15, 2011 | Elna 2007 Mechanical Sewing Machine
HOW TO THREAD THE BOBBIN ON THE BROTHER VX-1250!
Hello
Place a spool of thread over the spool pin, which is a vertical spoke located at the back-right of the top of the sewing machine.
Take the end of the thread from the spool and carry it left along the top of the machine and around the bobbin winding tension disc, which resembles a small button.
Pass the end of the thread through the small hole in the side of an empty bobbin, threading from the inside. Push the bobbin down onto the bobbin winding shaft, which is a small metal spoke at the front-right of the top of the sewing machine.
Click the bobbin over to the right, then manually twist it in a clockwise direction until you hear the spring on the bobbin shaft click into place.
While pinching the end of the thread that is coming out of the hole in the side of the bobbin, slowly press your foot down on the foot controller so that the thread from the spool winds around the bobbin. Let go of the thread end and continue pressing until the machine stops automatically, which means the bobbin is full, or when the bobbin has as much thread as you need for your project.
Cut the thread connecting the bobbin and the spool, and trim the thread end coming out of the hole in the side of the bobbin. Click the bobbin over to the left and remove it from the bobbin shaft.
The Lower Thread;
Turn the balance wheel (the disc at the top of the right side of the sewing machine) toward you to raise the needle to its highest point. Lift the presser foot with the lever located behind the needle shaft. Remove the extension table, if it is attached.
Open the shuttle cover, a small door located on the front of the sewing machine, underneath the needle. Remove the bobbin case, which you see held in the center of the shuttle race, by pulling the hinged latch on the front of it.
Pull about 4 inches of thread from the bobbin and press the bobbin into the bobbin case so that it will turn clockwise when you pull on the thread end. Slide the thread into the slot on the side of the bobbin case, over the tiny tension spring and into the delivery eye.
Hold the bobbin case by its latch so that the metal finger is pointing upward. Press the bobbin case -- with the bobbin inside -- into the shuttle race. The metal finger should fit into a vertical notch at the top of the shuttle race, and the bobbin case should be held securely in place.
Close the shuttle cover.
The Upper Thread;
Rotate the balance wheel toward you until you see the take-up lever raised to its highest position. The take-up lever has a metal loop at the end of a narrow spoke, and it will emerge from the top of the thread guide, the vertical **** at the front of the machine above the needle.
Take the end of the thread from the spool and take it left along the top of the sewing machine, around the rear thread guide, then toward yourself and around the front thread guide.
Take the thread down the front of the machine and from right to left around the tension control dial, which is the round knob to the right of the needle. Pull the end of the thread so that the part that passes around the tension control dial is taut and flush with the front of the machine. You should feel the thread slip between the two tension discs.
Carry the end of the thread upward from the tension control dial and through the eyelet at the end of the take-up lever. Bring the thread downward and hook it behind the thread guide, which is a small wire loop at the top of the needle. Insert the thread end through the eye of the needle from front to bac
Pull a tail of about 4 inches through the needle and pinch the end of it with your left fingers. Turn the balance wheel toward you with your right hand until you see the needle lower through the needle plate then rise back up again. You should see the lower thread looped around the upper thread. Untangle it and pull both thread ends until they have approximately 6-inch long tails.
If you have lost the original instruction manual that came with your Brother sewing machine, you can download one for free at the Brother website.
Jul 12, 2011 | Brother XL-5130 Mechanical Sewing Machine
How do i thread my sewing machine if it doesnt
Place the bobbin flat on the table with the thread winding clockwise (comes off the top of the bobbin and points right).
Place the bobbin-case with the hole pointing up, insert the bobbin without changing directions.
Find the slot in the bobbin case, and pull the thread up and past the end of the spring until it clicks into place.
Insert the bobbin and bobbin case into the machine.
Thread the Needle, and give it about 6" extra thread past the needle, hold the thread taunt (from the needle) and rotate the handwheel (top comes toward you), after a turn or 2, gently pull the thread from the needle and lift up the bobbin thread from the slot.
Break a Leg
Jan 03, 2010 | Sewing Machines
Threading a bobbin on the new home 2014le
place spool of thread in , route it towards your bobbin holder, take thread and put through one hole about 4 inches hanging ontop. press it in and slide it to the right where you hear a click, hit the peddle, should be winding, it will automatically stop on its own when full. click it to the left when done, snip it and then drop that into your bobbin holder , cover your plate, thread your upper thread and presto you are now sewing with your threaded bobbin, always remember these steps. #1 material choice #2 thread weight #3 needle size. you got to match those 3 for beautiful perfect stitches.
Dec 16, 2009 | New Home 2014LE Mechanical Sewing Machine
Can't thread the bobbin on a singer futura CE 150
Be sure the bobbin thread is coming off from the left. There is a picture on my Futura bed that shows the correct way to insert the bobbin. If the thread is comming off from the right you will have the problem you described.
Good luck,
Beth
Jun 29, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
87 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
