Question about Whirlpool Dishwashers
My dishwasher will not stop filling up with water. Even when i'm not using it. How can i fix this problem
    Sergeant:
    Champion:
  • 226 Answers
Check the water over flow for the cut off is got to be bad
Posted on Oct 15, 2010
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
Water not heating up
see this causes and fix it. God bless you
will not run on cold water or even luke warm water, it has to be hot water. Most will even specify 120F or hotter water temp as incoming water. These new units only use 1.5-3 gallons of water for each fill, so the temp has to be there. Many brands recommend that you run your kitchen sink water until it gets hot, then start filling your dishwasher, we also recommend that. Some dishwashers will stop if it senses too cold of water coming in, others will try to warm the water and if it can't in so much time, the unit will stop and give an error code. Hot water also helps dissolve and mix the soap detergent better, giving you better washing results. Just make sure the water is hot going into your dishwasher, no getting around it.
Oct 16, 2012 | Hobart Am-12a Commercial Pan Pass Thru...
When the dishwasher not in use, it filled the water up by itself. And after it was full, the water leaked out to the floor. Even after I turned off power, it cannot stop. I have to shut the valve under the...
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
May 10, 2011 | Frigidaire Professional Series 24 in....
Maytag dishwasher wont stop filling with water
if unit continues to fill even with power removed then the water valve is faulty. if not a md # will help.
Feb 01, 2010 | Maytag Dishwashers
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Kenmore dishwasher. The upper rack is not getting clean. Even very light residue remains. And, detergent is left in door at end of cycle. The bottom is filling up, so I don't think it's the intake valve....
I find it odd that the dishwasher is filling with cold water if the water is hot at the sink. It sounds like the dishwasher is connected to the cold water line rather than the hot. Check under your sink; if you've got standard plumbing, the dishwasher supply line should be connected to the left water pipe.
Regardless, the water temperature doesn't fully explain the symptoms, especially the detergent left in the door (assuming you're using fresh detergent and it's not caking in the door prior to washing).
I would check the blades again. Even thought they may appear clean, there may be debris in them that get forced into the openings during operation, but fall away from the openings when the water flow stops. Remove the blades, run water into them, then invert them to drain while rocking back and forth. If there's crud in them, you may need to do this several times.
Sep 14, 2009 | Dishwashers
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
General Electric Pot scrubber Dishwasher
From what you are describing, the fill valve may have failed or become clogged. Start the dishwasher, when the water stops filling, open the door and check the water level. There should be at least an inch to an inch of water in the center of the tub. If not, replace the water inlet valve.
If you need further assistance, let me know with a model number
Regards,
reg501
Jul 21, 2008 | Dishwashers
Dishwasher conitues to fill even if unplugged
If the dishwasher is filling with out the power on, you have a defective inlet water valve. If it's new, have them repair it under your warranty. If not the part number is wd15x10003. Easy fix, on the left side behind the toe panel...Catriver...post back.
Aug 14, 2006 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
