What are the correct calibration settings for the Sharp AQUOS Quattron LC46LE810UN LED TV?
romsky79
  • 822 Answers
SOURCE: Sharp Aquos 46in led tv power.
your power supply is damaged due to long time using without unplugged after use. its overheat cause. don't leave at stanby mode.
Posted on May 28, 2009
  • 1779 Answers
SOURCE: I am trying to connect my bose cinemate speaker
I assume you have everything hooked up? You should have the Audio Out from your interface module connected to the Audio IN of the TV. The sound should be set to fixed, not variable. Variable means you control the sound output from the TV which controls the sound from the Bose. Not Good. Sound quality is not as good and confusing to customers. Make sure your selecting the right tv input on the Bose system. You should be good to go.
Posted on Dec 27, 2010
gopakumarg43
  • 74136 Answers
SOURCE: What do I need to
Hello
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
Posted on Mar 14, 2011
bshldn
  • 736 Answers
SOURCE: How to adjust for best picture a Sharp Aquos
This sounds like a setting that can be adjusted. What I like about some of the Sharp televisions is the av mode setting (preset brightness/contrast adjustments). I am not looking at the manual for this model so I'm not sure if this is an option on this television. However with this being a high end aquos model there is free assistance available to you. You can register your television at aquos advantage and chat live with an aquos advisor at Sharp's Midwest Corporate Headquarters. The agent may advise you to call in if your television need and Industry Initialization because you have to be talked through it. I advise the chat reps initially because when you call you aren't able to speak with the Midwest Corporate Sharp reps unless your call is being escalated.
http://www.aquosadvantage.com
Posted on Apr 22, 2011
bshldn
  • 736 Answers
SOURCE: I'm needing a replacement stand
The stand and the screws you will need for them can both be purchased at encompass parts.
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEARCH&mres=1&mrpn=SHALC46LE810UN
Posted on Jul 18, 2011
Reset secret number on sharp aquos
ROFLOL and we are supposed to know it .or guess ,or read your mind from afar .
Nov 21, 2015 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp aquos lc-46le810un won't power on, psu diode zener and fuse blows..cause?
Unhook the PSU from everything that you can and turn it on, see if it blows anything out. If it does not then you are looking at a non PSU problem. If it does then it is psu. You need to get the schematics for this set if you can.
Aug 09, 2014 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Screen broken on tv
Sorry to hear that, sadly a replacement screen is most likely out of the question. It will cost more to replace the screen vs. buying a new set!
Nov 05, 2012 | Sharp AQUOS Quattron 60" 3D Full HD 1080p...
Screen is not full on tv
Try to go to menu settings,, and change aspect ratio and make it auto or full screen ,what suits your vision
May 15, 2012 | Sharp Aquos Quattron Led LCD TV
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
I'm needing a replacement stand for my sharp aquos model LC46LE810UN
Jul 18, 2011 | Sharp LC46LE810UN 46 in. LCD TV
Televison & Video Logo
216 people viewed this question
Top Televison & Video Experts
Electro Med Services...
