Question about Quintum Tenor AXG2400 (501014500) VoIP Terminal Server
What is the cause and the fix for a AXG2400 when only 1-2 ports on the FXS phone go into a timeout. The phone appears to be off hook and the status shows a call in progress when there is no call in progress. The phone on that port becomes dead with no dial tone. This seems to happen more in the 24 port than in the 16 port. I have seen this a number of times. I have tried disabling and reenabling the port but after a reboot, the ports go back off hook. Is this a wiring issue at the 66 block where circuits may be spiking each other on the amphenol cable?
2 Suggested Answers
  • 1116 Answers
SOURCE: how can I program off-hook automatic dialing for a
Tenor AXG VoIP Gateway (AXG800, AXG1600, AXG2400) Configuration
The Tenor AXG VoIP Gateway Configuration is used for (Phone/FXS) to VoIP connections; calls
coming from the Phone/FXS interface (i.e. PBX) may be switched as a VoIP call. Calls can be
routed in any direction between any of the ports. See Figure 1-8 for an example of a call originating
from the Phone/FXS side (PBX).
Tenor AXG Phone/FXS Originated Call Sample
PBX Keyswitch Phone - -> FXS Port --> FIOS IP Network
Posted on Jul 09, 2011
Port error 316 resolution
Please follow link provided by microsoft http://support.microsoft.com/kb/885425/en-us
Instructions
1.How to Fix Computer Port Problems on Vista/Windows 7/8
o1
Click on the "Start" menu. Double-click on Computer
o2
Right-click on the C: drive and choose "Properties."
o3
Click on the "Hardware" tab. A list of the computer's ports will appear.
o4
Double-click on the first port on the list and check the device's status. If the device is working properly, move on to the next port on the list until you find the problem port. The port's device status will indicate either that this port is not detected or that there is a problem detected with this port.
o5
Click on the "Driver" tab and click "Update Driver." Click "OK." Check the status of the port to see if the computer now detects it. If it does, the problem should be fixed. If not, repeat the steps.
Aug 08, 2014 | HP ENVY dv7t Quad Ed. i7-3630QM - 2.4 GHz;...
Audio distortion bogen tpu100b
This is am Impedance imbalance. Most inputs are looking for 600ohm. You need to use a different input or get a way to change you FXS to something else. What we usually do is buy the cheapest IP phone you can and wire directly to speaker. then simply call phone and it will page
Dec 17, 2013 | Bogen TPU100B TPU100B
Need to hook up vetch cordless phone to my internet modem/router
Hi, this phone is analog so it can only be connected to a standard phone line, if your router or modem has a FXS connector (phone jack) with an active land line service, you could connect it there.
Aug 02, 2013 | Vtech CS6719-16 Cordless Phone with Caller...
Application registry.wait for (0x7c802477365c3985) timeout
my blackberry appears in the following Applicationregistry.waitfor (0x7c802477365c3985) timeout
Jun 04, 2012 | RIM BlackBerry Curve 8520 Smartphone
How does and Atlas 550 split to analog
The Atlas 550 is modular, and can break out the 23 channels as BRI or FXS. Since you want 23 analog lines, I presume you want regular 2-wire phone lines (aka, FXS lines). The you that by using 3 "Octal FXS" modules (8 port modules) in addition to the T1 module.
Read more here: http://www.adtran.com/web/appmanager/portal/Adtran?_nfpb=true&partNumber=1200305E2
Nov 21, 2011 | Adtran Atlas 550 (4200305L3) Multiplexer
Hi i want connect a 7730 phone call to fxs port dvg 5008 .. what settings should i do?
A 7730 is a Panasonic system phone. It requires a Pana system to operate, so I'm confused as to what you're asking. If the phone call is INTO a 7730 phone and you want it to a phone on the DVG, you will need something to transport it, like an FXO circuit tied to the Panasonic's station ports. If the phone call is FROM the DVG and you want to answer it on a 7730, you plug the FXS ports into the CO ports of the Pana Key Service Unit that the 7730 is plugged into.
Hope it helps.
Carl
Mar 13, 2011 | Panasonic KX-T7730 Corded Phone
HTC P3400i
Hopefully you mean the south of the USA if so here you go
GPRS Web Session:
Homepage: http://172.23.1.135:8080/cellularone.wml
Service Type 1: WAP
Gatewap IP 1: 172.23.1.252
Port 1: 9201
Service Type 2: WAP
Gateway IP 2: 172.23.1.252
Port 2: 9201
Timeout: 15 minutes
GPRS APN: cellular1wap
MMS Web Session:
Homepage: http://www.openmobilealliance.org/
Service Type 1: WAP
Gateway IP 1: 172.23.1.252
Port 1: 9201
Service Type 2: WAP
Port 2: 9201
Timeout: 15 minutes
Aug 26, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Duplicate/incorrect MAC addresses in the CAM table
This is from the Cajun P333R manual but it should be very similar if not identical.
Good Luck.
arp timeout Command
Use the arp timeout command to configure the amount of time that an entry
remains in the ARP cache. To restore the default value, 14400, use the no form of
this command.
The syntax for this command is: arp timeout <seconds>
The syntax for the no form of this command is: no arp timeout <seconds>
Examples:
To set the arp timeout to one hour:
Router(configure)# arp timeout 3600
To restore the default arp timeout:
Router(configure)# no arp timeout
ip-address IP address, in dotted decimal format, of the station
hardware-address 48-bit address of the local data link
seconds The amount of time, in seconds, that an entry
remains in the arp cache.
Nov 09, 2007 | Lucent Cajun P333T Networking Switch
Rio Carbon stuck "WRITING"
The writing message may appear for a good forty minutes after completing the firmware upgrade - make sure your player is fully charged and just let it sit for an hour on that writing status - it will stop eventually.
Sep 10, 2007 | Rio Carbon MP3 Player
No output from serial ports
This sounds like an IRQ inturrupt issue. Do you have other serial devices on this computer? If so, you might consider removing any other serial devices and see if the problem resolves itself. If it does, you will need to reconfigure one of the devices to another IRQ so that they don't interfere with each other. Dan
Apr 11, 2007 | Magma PCI DMA Serial Adapter
Computers & Internet Logo
Top Quintum Computers & Internet Experts
David Payne
David Payne
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
