Question about Rheem EcoSense by 7.4 GPM Tankless Water Heater Natural Gas High Altitude
I am occassionally getting a moaning vibration, seems to be in the gas line. 1" supply to the house 3/4" branch for the waterheater which is the first appliance. hard piped all the way, is it possible there is not enough supply ?
  • 843 Answers
Maybe, but if it works OK and you only need to eliminate the vibration then it's going to be one of two things. The pipes themselves might be vibrating, or you may be getting a regulator and gas vibration (like a flute or a horn). As a simple test, try putting a locking pliers or a heavy c-clamp on the pipe, maybe in a couple of places. If this eliminates the problem, then it's the pipe vibrating and you only need to clamp some weight in place as a permanent solution, but don't make a direct metal connection unless you're certain the metals are the same. If that doesn't eliminate the problem then its the horn problem and you could make a geometry change (changing the length of the pipe - adding a couple of bends with additional fittings) good luck
Posted on Oct 15, 2010
Where are the shut off valve to cut the water off
Should be on top of the water heater cold water supply.
Feb 23, 2015 | Water Water Heaters
Sewer lines
Sewer lines can be 3 feet deep to 25-50 feet deep depending on location.
http://waterheatertimer.org/Sewer-construction.html
Residential sewer lines are generally 3-5 feet on flat yard depending on local code.
Deeper lines if house is on hill etc.
Local permit board might have drawings and general elevation.
Locate manhole near house to determine which direction main sewer line runs. Main sewer line will be 20 or more feet deep. However homes do not connect at that depth. Homes connect at shallower depth on a branch pipe, and then branch drains into the main sewer line.
Jun 01, 2013 | Water Heaters
On demand hot water heater leaking
is this an area w/a threaded fitting?if so ,you turn off waterheater,drain,disconnect existing fitting,clean and rewrap with new teflon tape ,and retighten down.i only say to drain,because i am not sure if it is hanging and would not want to fall on you.teflon tape and rewrenching down should fix,unless soldered.then call your plumber.also if under warr.from installer ,less than 1 yr.,call them and tell them to fix it for free.i have over 13yrs in sheetmetal install,both in hvy.industrial down to many other types of home install of furnaces,a/c units,retrofits in /new and existing homes,waterheaters,garbage disp,refrig.water lines,gas etc
May 21, 2012 | Bosch Water Heaters
My old Aquastar tankless natural gas water heater used 1/2" gas line. My new Bosch 2700ES -NG says it requires no less than 3/4" inside diameter gas line. Do I have to replace all the gas supply lines...
None !!
3/4 pipe from gas meter or regulator. At low pressure there may not be enough gas flow through a smaller pipe for the boiler when on full bore.
The boiler input pipe will be 1/2" needing a reduction from 3/4 so there is some leeway.
I have about 8' of 1/2 pipe on mine [Bosch Worcester] from the reg. and it is ok.
You could use the existing 1/2 and try. No harm done if insufficient-just replace. If you have some other gas takeoff on the same line a 3/4 pipe up to that take off is most likely.
Jan 29, 2010 | Bosch 2700ES Natural Gas AquaStar ...
Kenmore waterheater piezo innotor won't re-light
air in the line, disconnect the pilot supply and hold the button until you smell gas coming from the valve, that will remove the air, as for the igniter, test it by removing the connection and hold it about 1/8" away from the conenction and click it, should see a spark
Sep 16, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Takagi TK-JR vibrating noise
Remove your hydronic pump and replace the flexible impeller coupling that couples the impeller blades to the pump motor. make sure you don't do this on a sat or, sunday (i hate house calls then) and, be sure you have a new pump housing gasket before you start the job. Also check the unit for loose pipe brackets
May 20, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
I have the same problem with a T-K3. The Takagi support site recommended cleaning the burner. When the plummer arrived to attempt the cleaning, he was not convinced that it would help. He called the Takagi 800 number and let them hear the problem over the phone. They had him set the fan speed dip switch (#4 on the upper left bank of switches) to the up ("on") position and reset the system. Problem resolved! Why they didn't recommend this when I contacted them, I haven't got a clue. Anyway, the system hasn't vibrated in several days of use.
Dec 23, 2008 | Ultra Max Takagi Flash TH-1 Ultra High...
Turn on water the electronic ignition not coming on
The tankless water heaters require larger gas supply lines because of the on-demand consumption. While I don't know your units rating, most Propane Tankless Waterheaters require 2" supply lines. Moreover, pressure is directly related to temperature which sounds like your problem entirely; consider the run of the gas pipe from the tank and the ambient temperature. Now you see why plumbing is a hard profession to fake... =)
Nov 19, 2008 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Rheem EcoSense by  7.4 GPM Tankless Water Heater Natural Gas High Altitude Logo
368 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
