Question about Technics Audio Players & Recorders
I have purchased a vintage technics tape-deck that is pre-set for A/C 220V with a round pin plug, how can I adapt it for use here in Australia?
  • CPCI
    CPCI Oct 15, 2010
    what is the model, type and manufacturer ?
    do you have the manula for this tape deck ?
  • Sylvia Womersley Oct 15, 2010
    It is a Technics M205 made in Japan and I do not have a manual!
    Genius:
  • 1,325 Answers
Http://elektrotanya.com/technics_rs-m205_sm_2.pdf/download.html
that is the PDF manual for the RS-M205 Technics
Posted on Oct 15, 2010
How do I install a sony ES-R11 cassette deck in my car?
This is best done after consultation with a Technical person at Crutchfield where they have the adapter cables that link car to unit.
Aug 12, 2015 | Sony Audio Players & Recorders
The volume on technics SL-BD22 turntable will not turn up and stays at one volume
Since the turntable itself doesn't have a volume control the problem is with the amp it is connected to. It should be connected to an amp with a dedicated phono socket. It's no use connecting it to a tape or aux or CD socket. These sockets do not have a built in pre-amp for the magnetic cartridge. If your amp doesn't have a dedicated phono socket then you can buy a Magnetic Cartridge Pre-amp that will plug into a tape socket etc on the amp and have the deck plugged into it. If plugged into a none dedicated socket though you can hear it, the volume will be very low compared to other sources. If you have got it plugged into a dedicated phono socket and the volume is still low, then the internal built pre-amp inside your amp for the deck has failed and will need to be repaired. The pre-amp failure will not effect any other functions of the amp.
Feb 24, 2015 | Technics SL-BD22 Turntable
Is there a 120/230v switch on this unit. this unit has the European plug in with rounded ends. would I need to purchase a 120v adapter.
IF the unit is a international model it will say the two or range of voltages on the serial number tag. If it is not then you can use a 220 to 120 voltage transformer but if using a 60 Hz transformer in a 50 Hz environment they have the tendency to over heat.
The international model have a switch arrangment on the back to select different primary transformer windings. If you have a 220V ac unit a small 120 to 220V transformer could be used with no danger.
It is not just a matter of the connector but also of the voltage provided to the unit so that it works correctly.
Apr 17, 2012 | Teac W-860R Single Cassette Deck
I have a Technics RS-TR474M2 double reel tape deck. Fully functioning but no audio
Probably something in the pre-amp section that is common to both channels. Perhaps an IC?
Feb 21, 2011 | Technics Audio Players & Recorders
Compatbility of product in Australia?
if you connect the boombox direct to the your mains of 240v, the appliances will blow up , to avoid that you need a step down transformer to connect the boombox before it goes into the mains source. you do not need any adapter, only if you want to use battery that is when you to swicth to 12v
May 25, 2010 | Lasonic TRC-931 Cassette Boombox
I cant get my record deck to work on my technics sh-dv290 from the aux why
Is the aux imput for tape or cd only? Or is it a dedicated phono imput?
If it is for tape or CD only it won't work has the cartridge from the deck needs a magnetic pre-amp.
If the amp doesn't have a phono imput you can get a pre-amp for cartridges from your local electrical shop. This will plug into your deck and then into the socket of the amp.
If the aux on your amp is a phono socket, assuming the record deck is working, then the pre-amp (inside your amp) for the cartridge has failed. It generally is located near the imput socket, chances are it will be single IC. It's a fair bet the IC will have failed, they tend to be static sensitive types prone to fail at the drop of a hat!
Oct 19, 2009 | Technics SUV500 2-Channel Amplifier
Hi i bought my technics 1210mk5's in america and when i gor back to ireland i had them converted to 220v as this particular model is not dual voltage. The 1210's worked fine then when i used a plug pin...
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Jul 10, 2009 | Technics SL-1210MK5 Turntable
Initial setup no sound from my end
When setting up receivers or amplifiers,
Following will help to determin or correct the Problem.
1) Do not plug any sources into the unit but power cord. Then wait for 0~5 second while an ear on top of the unit. See whether the clicking Sound can be heard. ** This will tell whether the actual unit has problem or not in Power Supply or in Power Amp Circuit. If it clicks, then The Amp/Receiver is partially OK. In other word, the problem may be something else. If No Clicking Sound, then Definitely there is Problem. Meaning The unit must be serviced by Professionals. ***NOTE: This applies to Modern Receivers or Amplifiers (I would say, the units manufactured after 1980.). Vintage Units may not Apply.
2) Make Sure Speaker Selector Switch for "A" is on.
3) If Above is met (if Clicks), By visual inspection, See if the Tape Switch (Source Select) or Tape Monitor Switch is on or not (Usually Tape 1 or 2 indicator lights). This switch mu be off!! or set to tuner.
4) Many of the receivers or Amplifiers has a Loop called "Main In/Pre Out" at the back of the unit. There must be horse shoes type pins in them. Otherwise it will not Sound. (Some units has a On/Off Switch near by those jacks and have to be on position).
5) Some Units has so called "External Processor Loop" similar to #4 above and the Switch is on the Face fanel usually. (Must be Off Position)
After the Steps #1~#5, if Everthing is Corrected, then the tuner should Sound (Unless there is proble with tuner).
Now Plug in one Source at a time.
****NOTE: When plug in Tape Deck, Make sure to plug in properly. Out of Tape Deck to Play of Receiver, In of Tape Deck to REC of Receiver. Otherwise (if Reversed), the Sound will be muted or No Sound Will Occure.
Jan 28, 2009 | Audio Players & Recorders
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Repairing or replacing old tape decks
Hi m522posner
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
Vintage Electronics
P.O. Box 941
1241 Conestoga Creek Rd
Florissant, Co 80816
Email: Bob@Vintage-Electronics.cc
You could have a go at freshening up the belts yourself:)
regards
robotek
Jul 10, 2008 | Sony Audio Players & Recorders
164 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
