Question about Samsung Washing Machines
My machine is still only 2 years old, but now it reaches the spin and just doesn't do it. Its like the spin is jammed. How can I fix this? Cheers
    Sergeant:
    Champion:
  • 226 Answers
Have you check the blet
Posted on Oct 15, 2010
I have the whirlpool model WTW495OXWD and it wont spin or drain,
see this causes:
It spins, but doesn't pump
drain line is clogged fix it,some sock is inside, take pliers and remove, if you can you need to remove the agitator, the propeel of pump can be defective replace.
It doesn't spin or pump
frozen pulley pump replace
It pumps, but the water returns
improve the drain line. if mayor that 4 inch cut of the diference, is a lower install air/gap siphon break assembly
Jun 21, 2012 | Whirlpool Washing Machines
Maytag top load washing machine 2 years old
This could be partly the clutch/break assy. You need to be able to run this with the lid open in the spin position. Activte the lid switch with a pencil or something. Reach in and hold the spin basket and then turn the washer on in spin. Hold this basket for 1-2 minutes then release it and let it reach full speed then stop the washer by turning the timer off or releasing the lid switch. See if the hard breaking/noise is better. Keep doing this untill it comes to a smooth stop and the noise is gone at the stop. Not sure this will cure the noise in the spin starting up problem or not, but start here. the clutch gets rust on the pads and this burnishes the break pads, removing this rust that makes it grab.
Goodluck..
Apr 05, 2008 | Washing Machines
Miele honeycomb care w 1712 drain fault comes on every wash
see this possibles causes:
God bless you
attached diagrams
see line clogged and fix it.
frozen pulley
improve the drain laundry, if drain hose reaches more 4 inch cut off the excess
May 16, 2012 | Miele Washing Machines
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Hi, i have a toshiba aw1150s washing machine. it was working fine all along, until it reaches the spin stage. it will empty the whole tub of water. when it tries to initiate a spin, it shows E2 and...
check the safety door switch,, its not going to spin unless that switch is working, ( you can by pass it to test it, Jump clip a jumper between the 2 wires ,, if that fixes the problem replace the switch
Jul 14, 2011 | Washing Machines
My 2 year old Samsung front loader washing machine will not spin the water out, it just sits there and hums
if its spinning but no water comes out then most likely the cause of that is that the pump is either on its way out and can no longer pump the water out or its plugged with something most likely a sock or some other debris...
if the washer does not spin at all then something is most likely jammed or another mechanical failure.. front load washers can be problematic especially if you don't go easy on the load size so id suggest having a repair man fix...its not recommended trying to do it yourself
Feb 08, 2011 | Samsung Washing Machines
Frieght train noise through the house
Sounds like the drum bearings have gone. Replacement in the uk would cost aroung £130 as it is very labour intensive.
Would not recommend it on a 6yr old machine as other problems may not be too far off.
Hope this helps & thankyou for using Fixya.
Jan 25, 2009 | Hoover HTC243 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
10 year old top loading washer. Moved it out to clean behind. Now, when it reaches a higher spin speed, something is off balance and it jumps around. It is perfectly level.
be sure rear self leveling legs have dropped down properly lift up at rear and let drop or pry down jammed leg with screwdriver
Apr 27, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
