Question about Dishwashers
Top rack arms spins, but the dishes are always dirty.
    Sergeant:
    Champion:
  • 226 Answers
But is it heated up
Posted on Oct 15, 2010
Why are hype dishes on the top rack of my Ge profile dishwasher dirty? The upper two arms do not spin, but the lowest one is strong
There is a plastic filter down inside the pump inlet that clogs up on these. It can be difficult to remove without breaking things. d26b8b16-9f7c-47f1-863b-1baebb58de21.jpg
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 07, 2014 | GE Profile PDWT180VSS Fully Integrated...
SHU43C06UC dishwasher cleans dishes on bottom rack but leaves dishes on top rack dirty
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
Nov 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Top rack of Kitchen Aid not clean
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Sep 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
No-spin
the spinning of the arms is created by the force of the water shooting out of the holes. your top arm may have debris build up in it that prevents proper water flow. u can also remove the arm and see it there is build up on the contact point were it rotates. clean it if its dirty. "dishwasher magic" is good for cleaning mineral build up in your system. also, make sure your not putting dishes on the top rack that are too tall and prevent the blade from rotating
Dec 01, 2008 | Maytag MDB9600A Jetclean II Built-in...
GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
Jan 26, 2008 | KitchenAid 24 in. KUDK02CR Built-in...
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
