Question about Maytag Washing Machines
I have a maytag front loader (neptune). Fabric softner won't dispense during the rinse cycle. I've taken apart the dispenser and all hoses cleaning completely. It continues not working?
    President:
  • 1,294 Answers
Is there enough pressure in your wall faucet for the machine; should be good pressure. You can dilute the solution with water.
Posted on Jun 02, 2008
I have a frontload. The bleach is not dispensing. I have taken it apart and cleaned it but that did not seem to help. I do not use fabric softner so not sure if that side works
i have a maytag neptune 6500. we have tried both the bleach and the fabric softner. neither work. we've tried selecting every option on the machine, cleaning it, using hot water instead of warm; nothing is working.
i packed up the manual in the process of moving so i can't get to it right now. i'm surprised there's no solution yet online!
sorry this isn't a solution, but more problems.
Jun 25, 2010 | Maytag Neptune MAH6500A Front Load Washer
My stacked Maytag front loader leaks out through the door when the fabric softener dispenser is being filled (2nd rinse cycle only). Any help?
The second rinse is when the softener cup is being flushed. Remove the dispenser and clean and inspect the housing to be sure no softener is gumming up the holes and blocking the water flow into the machine.
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softner compartment won't dispense during wash cycle
Fabric softener is to slow mix with rinse water in the rinse cycle... check the cold water supply line for a clogged screen or a clogged dispenser box cover... hope it helps
Sep 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag neptune washer is dispensing fabric softner during wash cycle! help!
not good. the board usually tells the dispenser to activate and send water to you fabric softner, ive seen two different problems on the maytags, your water valve could be bad or clogged or the board is bad.
Sep 17, 2009 | Maytag Washing Machines
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
Washer leaves fabric softner stain on white clothes
Dispenser wholes are probably clogged and all the softener is not dumping when it is supposed to!. Top loaders usually have a little cup like place to add the softener in the top of the agitator!
Those the Manuel tells you to rinse with water occasionally!
If you can't figure it out, call service and get it done and over!
You will feel better!!!
These guys are good
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jul 28, 2008 | Maytag Performa PAV2200
Rinse Cycle
The fabric softner won't dispense and I was told to replace the dispenser unit, is that the solution?
Jul 22, 2008 | Maytag MAH8700A Front Load Washer
NEPTUNE WASHER
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
Feb 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
