Question about Cycling
I took the axle on my schwinn beach cruiser off and dont know how to put it back together
  • 3 Answers
SOURCE: hampton cruiser axel manual
sounds like a spacer is missing or you have over tightend the wheel nuts way to much.
Posted on May 14, 2009
SOURCE: how do i put it back together?
Here are some pictures that helped me reassemable my powershot 5700 back together.
vette007
Posted on Jul 05, 2009
  • 202 Answers
SOURCE: putting the dremel back together
here is a link to a 215 should be similar in design.
http://www.ereplacementparts.com/dremel-215-f013027506-corded-multitool-parts-c-15440_15456_15457.html
Posted on Jul 09, 2009
SOURCE: How to put back together a smith & wesson air soft rifle
ooof i know how to put i back together and can teach you but its a doozi over the net. hows your experiance with airsoft internals also wat type of gun is it (spring gas aeg etc shotgun assault rifle pistol etc. email me @ levis_lalancette@yahoo.ca i can help you further with that info
Posted on Aug 04, 2009
shadtremonky
  • 353 Answers
SOURCE: how to put a steering wheel back together
special tool required
Posted on Aug 07, 2009
How many ball bearings are there supposed to be on each side of the front axle of the Schwinn Point Beach model S4852WM bike?
There will always be a small gap in the bearing ring, and not all hubs take the same amount. However, if the balls are 3/16" there are almost always 10 on each side. If they are 1/4 inch (less common) then 9 is the correct amount. DO NOT replace only some of them - replace only in a full set of 20 or 18.
Sep 10, 2016 | Schwinn Cycling
My chain has fallen off, and I can't put it back on. Every time that i think I have it on there again, it falls off shortly after. I don't know if the first time it happened something feel off too...
Hi emsfy...
When you put your chain back on this time, you will need a open end adjustable wrench or a wrench that will fit the nuts that are on the rear axle shaft and wheel assembly.
When you get your wrench, loosen the two nuts (1 on each side of the axle) and pull the axle wheel assembly back towards the back of the slot the axel is sitting in to tighten the chain, when the chain is tight you will tighten the two axel nuts and the job is finished.
The chain will stay on now.
Please take time to rate me thumbs up
Sep 12, 2011 | Schwinn Bikes 26 Womens Southport Cruiser...
How do I switch gears on the Schwinn Roxi Beach Crusier. I just bought it used and dont know how to swith gears?
Search engine "how to shift gears": or find the generic bike manual for Schwinns which can be found by searching for "schwinn bicycle manual". See how that works?.
Aug 17, 2011 | Cycling
I took apart the back wheel of the bike and now dont know how to put the bearing and axle back together
I take it your bicycle has a coaster brake. Can you tell me what brand the hub is? It is probably stamped on the brake arm that attaches to the frame.
Aug 10, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
My old Schwinn 26" red
Web search "fix shimano internal gear hub" or whatever the bike has.
Aug 09, 2011 | Cyclone Bicycle Pedal Crankset And Arms...
In putting together my 26"
Loosen both nuts on front wheel.
Stand bike straight up, or set bike upside down on seat and handlebars.
With fingers on fork and thumb on wheel, pull wheel so it is centered on fork.
Now tighten one nut part way. Keep holding wheel.
You may need somebody to help.
Then tighten other nut.
Go back to fist nut and tighten a bit more.
Repeat back and forth tightening until nuts are tight and wheel is in center of fork.
Dec 25, 2010 | Schwinn Men's 26" Jaguar Cruiser Bike
SCHWINN AIR DRIVER 1100:HOW DO I USE IT TO PUMP AIR INTO BEACH CRUISER TIRES
SCHWINN AIR DRIVER 1100How do you assemble the air pump for bike tire
May 09, 2010 | Cycling
Cycling Logo
32 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
