Question about LG DLE5932W Electric Dryer
My whirlpool LGR5636LQO gas dryer does not heat up and runs constantly.
  • LG Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Our Whirlpool Model LGR4634JQ0 will not heat up. I took the peep hole cover off and watched as I turned the gas dryer on (high heat). The chamber heats up and glows bright orange for maybe 15-20 seconds...
You're a good detective! Gas dryers have an ignition panel (what you saw glowing bright orange) that heats until it reaches a certain temperature. This temperature will cause the gas from the pilot to ignite and the dryer will run, staying at a constant temperature and thereby drying your clothes. It sounds as it your ignition panel needs to be replaced. It is a relatively simple process if you are comfortable making repairs. If you aren't, I suggest calling a repair professional. We did this a num ber of years ago. The repair service was reasonably priced and our dryer worked for another 6 years!
Good luck. If this works, please return to Fixya and rate my advice!
Jul 31, 2011 | Whirlpool LGR4634J Gas Dryer
My dryer spins but does not get hot anymore and the knob does not move so the dryer just spins constantly. Constance Livingston
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 13, 2011 | Whirlpool Dryers
Whirlpool dryer runs but does not heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | Whirlpool LER4634J Electric Dryer
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool LER4634E2 is running and will not dry? is it the heating element? how expensive are these? I bought this used. :(
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Dryers
Whirlpool gas dryer no heat
The problem is probably with the ignitor...these are very fragile and burn out easily or crack...
Replace it and you will be working again...
Here is a tip on how to fins the part online...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 04, 2010 | Whirlpool LGR5636L Gas Dryer
Does not run or heat
check the high limit cutoff stat and if you see the igtn glow red and a click after the problem is in the gas valve
Sep 03, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Dryer no heat but runs
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
LG DLE5932W Electric Dryer Logo
128 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
