Question about Frigidaire FEB27S5A Electric Single Oven
OVEN TEMP STUCK ON 100F
Frigidare model# FEB27S5ABB single oven. When setting temp for bake or broil the reading changes after a few seconds to 100f and does not change-oven and broiler does not heat at all. Tried breaker switches. Any ideas?
  • BWOLFJR Jun 02, 2008
    bake elements not heating, have not used self cleanning, not check connections.
  • robert samples May 11, 2010
    is the bake element hearing and have you self cleaned it and have you checked the connections at the oven to the house
    President:
  • 1,314 Answers
Check your house connections to the stove turn the breaker off first then reply to me
Posted on Jun 02, 2008
  • sheryl kells
    sheryl kells May 14, 2015
    Hi I am trying to get my stove working ,I have the same issue when trying to use my oven it accepts 350 but after a few seconds flips to 100!
    I have checked the breaker,reset the clock and still no different.could you give me some steps on what to test.
    The convection fan runs fine, it's the broiler,bake element and clean feature that are not working.
    I used it last night no problems I am ready to throw this thing over the porch rail arrrgh!
Why will my broiler work but my bake will not?
Good Afternoon Friend,
I understand that the broil element is heating in your Frigidaire oven, but the bottom bake element will not heat. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When you restore power you will need to set the clock. Preheat your oven using the bake option. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Ovens
Model RBS275PDB12. I had a recent Power Failure. Since the oven has malfunctioned. When placed on bake the preheat timer does not display. At 350, the baking element gets warm. At higher temps the...
Good Afternoon! If your Whirlpool oven isn't heating to temperature, and your temperature sensor is reading good, the control board may be the issue. Fixyourboard.com can test and if necessary repair the control board in your oven. We back all control board rebuilds with an industry leading two year warranty. Contact us for more information- info@fixyourboard.com
Thank you!
Mar 30, 2017 | Whirlpool RBS275PD Electric Single Oven
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Temperature in oven is way off
Jim,
A couple of questions... What makes you think the oven is off that far? If you have a set on the shelf dial type thermometer, throw it away. They are never accurate and generally read 50+ degree too low. I recommend the "biscuit test". Which is simply a cheap can of "hit on the edge of a counter top to open" biscuits and see how they bake with the instructions on the can. Make sure you allow the oven to preheat for 20-30 minutes (always but especially for this test).
To change the oven setting press BAKE, then run the temp up to 550 then immediately press and hold the bake pad for 10-20 seconds. The display should read 0 (zero) you can then use the up down arrow pads to adjust, hit bake pad again and then "clear" when done to lock it in but, you can only go up or down 35 degrees. If it is truly off by more than that you would need to change the main oven control board and oven sensor.
Dec 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool built-in single oven AKZ451/IX/01
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Nov 11, 2007 | Ovens
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
Frigidaire FEB27S5A Electric Single Oven Logo
270 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
