Question about Frigidaire Refrigerators
The top hinge pin assembly on the freezer is broken and makes a loud "snap" noise when opening or closing. Where can I get a OEM replacement?
    Sergeant:
    Champion:
  • 226 Answers
Have you try www.frigidaire.com
Posted on Oct 15, 2010
Front passenger door suddenly started to make a loud clacking/snapping sound when opening, sprayed lithium grease - no change
between the top and bottom hinge of the door you will see a flat plate thats fastened to the door and post its purpose is to smooth opening and closing the door check the securing bolts and nuts its known for them to come loose over time also the welded on nuts that secures it can break loose so that area is where the noise is coming from
Mar 11, 2016 | Cars & Trucks
How do you adjust the doors to closed completely?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Sep 03, 2009 | GE GSH22JFR Side by Side Refrigerator
REFRIDG DOOR OPENS A LITTLE WHEN I CLOSE THE FREEZER
Yes I think it's the door closing cam broken and worn away.To replace, Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips. Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Aug 30, 2009 | KitchenAid KSCS25FKSS Side by Side...
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
Open door position hold latch snaps real loud opening and closing the door
The hinge has most likely broken loose from the door frame. Look at the main body where the slider bar attaches to the body from the door. It is common for the hinge to break loose. It will need to be spot welded back into place to stop the clicking noise. Usualy two clicks when the door opens and then when it closes.
Apr 01, 2009 | 1999 Volvo V70
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Hinge assembly makes a snapping sound when door is opened
This is a self closer assembly. Try getting a new self closer and replacing both parts. The part on the door and hinge. 0The door must be removed to do this.
Nov 13, 2007 | Frigidaire FRS26KF5C Side by Side...
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
