Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman LT1000 riding mower with 18hp B&S engine. Mower acts like the battery is almost dead. Will try to turn over but doesn't seem to have the power to cycle the engine. New battery, starter, magneto, fuel shutoff, fuel filter, spark plug, air filter, oil & filter installed. All electrical connections are solid. I have had to use a jumper battery (even then it still struggles to turn over) every now and then and once running it performs flawlessly. The voltmeter on the tractor indicates 14 volts when running. No smoke or excessive oil consumption has been noted.
  • 110 Answers
There is a compression release device on the cam shaft to allow the engine to spin easier when starting. This is likely the culprit because the starter isn't strong enough to push the engine past full compression. The fix is to replace the cam shaft.
Posted on Oct 25, 2010
What is the valve adjustment?
its the clearance between the rocker arm and the valve on briggs engines i set them to .006
May 04, 2012 | Garden
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a LT1000 riding mower,the other day while i was mowing the engine just shut off.I tried to start it back up and does not do anything.Completely dead?
If the engine doesn't do anything then it is probably a bad relay on the starter. If it turns just a little bit, but not very fast then you either need to charge or replace the battery. You can take the battery to your local parts store and they should be able to test/charge it for you.
Jun 09, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can you tell me what battery is needed for an 18HP It1000 Craftsman riding mower? We suspect someone installed a battery with insufficient cranking power for 18HP engine.
I can tell you this. I have a 17 HP Craftsman and the battery specs are:
28 amp hour
230 Cold Cranking Amps, minimum
My case size is U1R, but yours may differ.
A good auto supply store can probably look up your specs.
If your current battery is less than this, you may be correct about someone installing an undersized battery.
How does your engine crank if you use a car to jump it?
Let me know.
Gary
May 30, 2011 | Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Trying to replace broken brake rod
Go to www.searspartsdirect.com. Put in your model number there, it will come up with parts list and diagram for your mower.
Apr 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT1000 Wont crank over.
This is not always the case but on Briggs and Stratton it may be time to check the valves for adjusting. Take off the cover and check for a gap of .005 . If the exaust valve is loose it will not allow the engine to relieve combustion to start. In other words the engine stays under load of compression and can't turn. In my shop I see this all the time . If all electrical checks out try this next
Nov 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
683 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
