Question about Refrigerators
The freezer lights are on, but compressor is not operating, and refrigerator is not cold at all.
    Sergeant:
    Champion:
  • 226 Answers
Try to find the capacity sound like it bad to me
Posted on Oct 15, 2010
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerators not getting cold all of a sudden
if just the refrigerator is not getting cool,check the cold control in the refrigerator and make sure its opening the damper door between the refrigerator and freezer to let cold air in from freezer,if the whole unit is not cooling i.e. refrigerator and freezer compartments, then the compressor isn't operating and the rtc overload contactor on the compressor is defective,its mounted on the compressors side and you unplug it to replace it,when its removed,shake it,if it rattles when shook this is a good sign its bad
Feb 09, 2010 | Whirlpool ET8MTKX Top Freezer Refrigerator
The lights are on in the refrigerator and freezer, but neither unit is cold. The thermometer on the refrigerator registers 55 degrees. Why is it not cooling??
First, make sure the compressor is running. It is underneath the refrigerator body. If the compressor is running, and you still don't have cold air, check the compressor fan. This should be close to the compressor. This fan draws air across the coils and removes heat from them. The compressor and fan must both be operating properly to get cold air.
Oct 18, 2009 | Refrigerators
Freezer and fridge not cold
Sounds like you have a stuck compressor. The buzz is the compressor trying to run but cannot.
A refrigeration mechanic with an hermetic compressor tester can reverse operate the compressor to get it unstuck
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refridgerator and freezer wont get cold
sounds like a bad compressor, or at least the start device plugging in to the compressor has gone bad,
Mar 15, 2009 | Frigidaire FRT21H8 Top Freezer...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
