Question about WYSE Winterm S30 Network Terminal
Cannot log onto network - get message "waiting for network services"
Hello: On boot - new Wsyse S30 units will not connect to our network. We receive a message on the screen " WAITING FOR NETWORK SERVICES". It does not see our network, gateway or DHCP server to be assigned an IP address
The network port, cable etc are fine as they work for other devices.
However once we hook the S30 unit up to the network it then crashes the switch which controls the network port & hangs the port which it was plugged into.
Any thoughts
Thanks
RReidt
On the DNS-server (Active Directory) you have to generate spesific IP-address for each thin clients MAC-address.
Posted on Aug 12, 2008
I cannot access the internet. I have an internet restricted message at the bottom right of IE on my WYSE S30. Dont know how to resolve/bypass this
Check the IP settings of the unit, IP address, gateway, and DNS... like alwayse start by setting it to DHCP or AUTOMATIC IP, that way you should receive all the right IP's from the DHCP server if that is not working than verify if you need to configure a PROXY SERVER
you should supply mor details for me to help (network infrastructure) good luck!
Nov 22, 2010 | WYSE Winterm S50 Network Terminal
Enter admin mode
I have 10 unit that belonged to Chase back, and it tries to auto connects to there DNS. I tring to reset the unit to factory default with out any success. I have tried just about everything. The remote connect flash don't work because it boot into auto connect with CHASE logo, then fails finding DNS screen. I was able to access the bios, and get into the control panel. I still looking for a way to reset to factory default without success. G, Control+G, Fi report has been used to gain access, but can't change the boot process from logging as CHASE with the auto connect. If you have a solution......
Nov 13, 2010 | WYSE Winterm S30 Network Terminal
Error code 80710b23
Hello Mr =)
80710B23 PS3 Network is Down or PS3 Network is too busy to respond
Jun 05, 2010 | Sony Playstation 3 (PS3) Console
Hello I have a D-Link DR615 wireless issue. it automatic set to FREE wireless. why?I used to have password and also assigned a name for it. but now the Assigned name is NOT in the wireless network, instead...
It seems as though your router was reset to the default settings.
In this case, you need to connect to the "DLINK" network and reconfigure the router.
If you have the disk, you can use that to run the setup, or you can log onto the router itself and configure the settings.
To log onto the router, open a internet window and type in 192.168.0.1 in the address bar.
This will log you into the router.
Now simply select "wireless" and then wireles security and you should be able to set up the password again.
Thanks,
Pat
Mar 31, 2010 | D-Link DIR-625 (790069292637) Wireless...
When I attempt to log onto my network I receive this message. ''Windows was unable to find a certificate to log you onto the network (network name)'' This is followed by ''Validating Identity'' which when...
This is caused by setting the encryption to WPA-RADIUS instead of WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.Switch the encryption to WPA-PSK (pre-shared key) on both ends and it will work.
Oct 11, 2009 | Toshiba Satellite 2400-S251 Notebook
Vista Home Prem - Failed to connect to a window service upon boot
You can go for an option of system resotre , that might fix the issue
May 19, 2009 | Microsoft Windows Vista Home Premium with...
N1 Drops when Mac log onto network
OMG I have the exact same problem. I'll be using the router for a week on wifi just fine, then one time when my mac laptop comes out of sleep and tries to connect, the router drops its Wifi network (making it unjoinable for any device, not just my laptop) and I ultimately have to hard-restart it. SO frustrating, this is on v1 btw.
HELP
Feb 20, 2008 | Belkin (F5D8231-4) Wireless Router...
WYSE Winterm S30 Network Terminal Logo
692 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
