Question about Lentek Steam Xpress SE01 Vacuum
I need to replace the water tank for my SE01-G-7A biagiante steam xpress and dont know where to order one. Cant find Lentek website.
Water won't spray when I squeeze the trigger. How do I get it to spray the solution?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your unit doesn't spray water. It could be that the !) water tank is empty which you can fill heavy duty bladder with hot tap water. 2) If Formula tank is empty, you can fill it with Bissell 2x formula for cleaning. 3) If tank may not be seated properly, turn the power off, remove and reseat the tank. 4) If pump may have lost prime, try to turn off and then turn on the unit, wait for one minute and depress trigger. If still nothing happens, I suggest you contact Bissell 1-800-237-7691 for further assistance.
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website
http://www.thinkcrucial.com/search?type=product&q=bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Jun 10, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover steam vac F6210 solution tank spring repair
Hi there. The spring on the clean water tank cannot be replaced. A replacement tank would be needed. Follow the link to order a replacement clean water tank for your cleaner. Search Results
The clean water tank does not include the handle but your original handle will fit the replacement tank as well. Hope this was helpful!
Jun 19, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Need new water tank. Will not stay attached.
I have one of these machines and I am missing the black cap that fits on the water tank.
If you need the tank only, then I have it. I found my manual and the website for Lentek is supposed to be www.lentek.com, phone 888-3LENTEK, email customerservice@lentek.com
Jun 20, 2011 | Lentek Steam Xpress SE01 Vacuum
Hi I have just purchased a Sieger Vapor Steam Mop do I need to put the clip on when steam cleaning tiles & lino or just for when I do carpets Cheers Lelly
you only use it for carpets. by the way, did you know you cant get the mop pads !!!!
Q to target customer service:
Dave: can i get some spare mop pads in store?
Cust service: no we dont sell them
Dave: ok where can i get some more?
Cust service: you cant, its a target mop
Cust service: its ok, you just wash them and reuse
Dave: yeah i wash my jocks, but i dont wear them forever, they wear out and i dont rub my bum on the floor
Cust service: you can't return it.
Dave: (NOT 100% happy, would you be?)
Feb 04, 2011 | Vacuums
Where can i get a replacement water tank? for model # F5906-900 series 12?
The replacement parts can be ordered from hoover or through any hoover dealer. thier info can be found through the Hoover website. If you are unable to obtain a direct match, there may be available ones in different color.
Oct 24, 2009 | Hoover F5906-900 Upright Steam Vacuum
1699 ProHeat Clear View Upright Steam Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49925&thid=639852
Posted by wmwmsjr on Jun 02, 2008
when the clean water tank is filled and set in the proper position the water steadily dumps on the floor when i inspected under the unit you can see the white rubber diaphragm approx. 3/4" in diameter exposed and you can see what i assume to be the suction line for the clean water when the handle is pulled it appears that there would have to be another part here some sort of cover or something to assist the diaphragm in holding back the water from dumping out of the tank until the handle is pulled does anyone have any photos of the bottom of the unit or know where i can get this part any thanks is much appreciated Bill
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There is a valve under the water holding tank that is probably giving you a problem and it is replaceable depending on if it is underneath the water holding tank or directly under the water tank. I am going to give you some phone #’s and websites that you can order parts from or fell free to contact your local vac dealer in your area for service and or parts.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Bissell 1699 ProHeat Clear View Upright...
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Mar 25, 2008 | Karcher DE4002 Steam Vacuum
Broken water tank on steam vac duel w/rinse #f7205-910
If this is a Hoover, you can go to thehooverstore.com and order what you need. But you will need your model number. You will have to replace the tank.
Feb 21, 2008 | Vacuums
Lentek Steam Xpress SE01 Vacuum Logo
155 people viewed this question
Top Lentek Vacuums Experts
JoeVacs
Are you a Lentek Vacuum Expert? Answer questions, earn points and help others
