Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Why does ice keep forming in the bottom of the freezer and how do we fix the problem?
  • A Miller Oct 15, 2010
    cause water flows down hill???
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 15, 2010
Drain is clear but ice stilll forming in bottom of freezer
Use a steamer to blast the drain clear... sometimes you need to install what is called a heat probe that feeds into the drain tube to keep it from freezing over... Help Me Find My Model Number RepairClinic com
Oct 04, 2016 | Freezers
Why does ice keep forming in the bottom of the refrigerator
If you are referring to ice forming on the floor of the freezer, it's a result of a blocked defrost drain. Contact Maytag to send out an authorized service company to make repairs. There is a drain kit that is installed at no cost to you.
Sep 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Ice continually forming on bottom of upright freezer
you nead to clear the drain.when you clear the ice you nead to make sure that the drain is clear.a spider can build a nest in your drain line.if you remove the ice,you nead to clear the drain line with a hose.you nead to blow though hose and clear line.
Nov 18, 2009 | Ovens
I have a Electrolux Frdige Freezer Model ERF 2830.
check appliance blog .com and type in your make/model,sometimes there are fixes on there
Nov 01, 2009 | Refrigerators
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Ice forms on the bottom of the freezer
Is this a result of defrost melt liquid winding up in the bottom of the unit? Find out why it is not draining properly into the pan. A slight bit of frost is normal.
Dec 20, 2007 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
