Question about Epson Stylus CX6600 All-In-One InkJet Printer
CX6600 SCANNER When I hit he scan button, it gives me the option of photo card PC and email...to scan it to...when i push OK nothing happens. Nothing. I cant seem to get te scanner to work! Please help!
  • Epson Master
  • 691 Answers
Download the Reference guide for your machine from th eEpson web site. It will inform you what you need to do to complete the scanning options. you can also download the Epson Scan utility to help with scanning to email etc.
Posted on Jul 16, 2008
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
Scanner does not scan stops after hit ok to save to pc shows scan page on display but nothing happens
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it ((browse)) select the file/folder where you want to save it (my pictures) most common
hope this helps
Dec 17, 2010 | Canon Pixma MP500 All-In-One InkJet...
How do I use the scanner on my printer? I push the scanner button and nothing happens.
You have to configure the scanner utility in the printers software that is installed in your computer in order to use the scan button and send the command from the printer to the computer.
This is completely different then using the scan option by accessing it in your computer and sending the signal to scan from computer to printer.
Lets try using the computer to printer option first as its easier.
Go to "start" on the bottom left side of your computer screen
Slide up to programs and locate your Canon Pixma software and open it.
Choose the "Scan" option and hit "ok". Then just follow the prompts.
If its the first time using the scanner option, the software may ask you to confirm your choices for the default when choosing picture or documents. In general the software already has the default choices that are best for your machine in these areas. So just leave them alone and confirm them to continue on and use your scanner.
If this does not work for you or other issues come up while trying these instructions please clarify them and I will help you until able to scan right now.
Sep 27, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My dell photo 942 won't scan
I would try deleting the scanner driver and software and reinstall. then plug the usb cable from the printer to the pc.
Jul 31, 2009 | Dell 924 All-in-One InkJet Printer
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Unable to use Memory Card with PC VISTA
The scanning software for your printer must be installed separately from the printer software on Vista systems. The following link will take you to the page to download the scanning software....just find your model number and select it:
http://www.epson.ca/cgi-bin/ceStore/support/supAdvice.jsp?BV_UseBVCookie=yes&noteoid=86150&type=highlights
May 03, 2009 | Office Equipment & Supplies
Canoscan 4200f Light on No buttons working when pushed
 go in the computer software like windows photo gallery and scan an image or document.If the settings are corect as you say it should give you the option to aquire image from scanner
Oct 02, 2008 | Canon CanoScan 4200F Flatbed Scanner
Printer won't scan a picture
I had the same problem, but I was able to scan my first photo today. If you are using Windows Vista and have Windows Photo Gallery on your system, you should be able to scan your photo/documents. Open Windows Photo Gallery 1. Click File, and then click Import from Camera or Scanner.
2. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
The rest should be self explanatory. Good luck!
Jun 17, 2008 | Canon Pixma MP500 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
