Question about Linksys 2.4 GHz 802.11b Wireless - B PCI Adapter (WMP11) (LINKSYSWMP11)
I can't reach my ip to change my lan config
I recently foolishly unplugged my modem from the beside the desktop computer. Now neither of my laptops will pick up my network. I reset the router and I do see the network (linksys unsecured). I'm sure this is me. But I can't access the 192.168.0.1 or 192.168.0.0. It tells me the search page cannot be found. The desktop that is directly connected to the router gets internet. But as I try and access those same ip addresses it tells me the oporation has timed out. I'm really scratching my head on this one. Please help!
    Problem Solver:
  • 5 Answers
Yeahlife,
The default IP Address for Linksys routers is 192.168.1.1. You may want to try accessing your router's configuration by typing this IP Address in your browser.
If you have any additional troubles, please let me know.
Regards,
moriarti5
Posted on Jun 02, 2008
I'm using an SB5101 and trying to use a new wireless router with this modem, but the set up is saying I have a static IP address... where can I find that on my computer whil I'm using my old router? thanks
I have one, after finding out how reliable and well-made they are. However, they can be picky during setup, especially since they have a rare 'config IP' address (the number you type into your internet browser's address bar to change the modem's settings). Click here >> 192.168.100.1
See this link for more info.
Mar 21, 2011 | Arris SURFboard SB5101 Cable Modem
I get laptop connection with N router, but desktop use is unavailable - saying "cannot find server, page unavailable, not connected to internet,etc"
if you your using your dektop with LAN then u have to configer you r LAn steup
go to folowing steps
1 my Networking place
2 write ckick on that icon , Properties
3 see the local area contection
4 agani properties
5 you will see the one big list select from that
6 internet protocol (TCP/IP)
7 just give the IP in usr the following IP addres
e.c. (192.168.1.22)
then try you dektop will work
May 04, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
Your router has an lan address or IP. Something like 192.168.1.1. This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between 192.168.1.2 and 192.168.1.225. As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like 10.0.0.1. So setup for one machine may look like this [192.168.1.3 subnet 255.255.255.0
To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
Mar 11, 2010 | Computers & Internet
How to open NAT on router
To open NAT
On the Windows Desktop, click Start.
2 Select Run. The Run window is displayed.
3 Type cmd /or/ command and click OK.
4 On Command prompt window (black screen) type ipconfig
5 Check the Default Gateway (192.168.?.?)
6 Open IE - on the address bar type http://192.168.?.? enter
It will open the router page
Gateway > LAN — nat config Page
Check Page No 47 on the Manual
Check the Manual
SBG1000 Wireless Cable Modem Gateway User Guide
Enable NAT If enabled, the single HFC IP Address (public IP address) assigned by the cable service
provider is mapped to many private IP addresses on the SBG LAN.
Jan 04, 2010 | Arris SBG1000 Wireless Cable Modem Gateway...
How to configure static route between 2 LANs?
the command what you have given is correct as per your explanation. If you could post the configuration, it will be good to fix the issue.
Jun 10, 2009 | Cisco ASA 5510 Firewall
Not able to configure and connect to internet using router
Try 192.168.0.0 which would be the default address to access your modem. This should allow you to go into the modem and adjust changes. I know on the bottom of my router there is an administrator default password that can e used to access the mainframe of the modem. Check out these features in there. I would start first by connecting via LAN again and then try to conntect to it via a WAN but again see if you can access the modem using the 192.168.0.0.
May 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My wireless modem doesn't appear on 'connect to a network'
You may have to configure the router and change some wireless settings to get it to work, goto the router configuration page, (run ipconfig /all, at a command prompt, to get the "ip address" for the rotuer config page, I believe it is the"Default Gateway" that you would enter in the address bar of IE to get to the page, (the pass will be user:Admin, Pass:Admin, orPass, or Password, or 12345 on some older ones) then click on the wireless menu's from the left.
I hope this helps, if so please give a fixya rating if it solves/helps solve your problem.
P.S. The router itself may be broken, and LAN may still work while WAN will be not working, usually buy a new router.
Thanks,
Gomez
May 16, 2009 | NetGear WGR614 Wireless Router
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Vista/router/wireless connection
Make sure that all the wireless cards are set in the properties to obtain an ip address automatically, dissable the wired lan adpter connections as this can confuse the router. Restart all the pc's and then right click on the wireless pc icon in your task bar and then click view wireless networks and make sure that you are connected to your network and that the internet is available, known as local & internet in Vista. open up internet explorer, go to tools, internet options and delete browsing history cookies and temp files and then refresh the page as the proxy server will need to refresh.
Sep 24, 2007 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
