Question about Garden
My John Deere 400 won't move. It was working fine and when I was changing directions it stopped working. If I raise the wheels off the ground and shift it, the wheels turn like they should, but it doesn't have enough force to move the machine, I can hold the wheels from turning with my hands. It did not lose power gradually, it happened all at once. It has plenty of fluid in it. The transmission is a Sundstrand model 90-1142, serial # 04-PC 55229. I thought it might be a relief valve open but I don't know where it is. Where can I get a repair manual or parts list, I have spent hours on the net looking for info and have found nothing.
ButtFuzz
  • 463 Answers
SOURCE: IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
Posted on Mar 26, 2009
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
  • 143 Answers
SOURCE: Three point hitch on 2020 Jogn Deere Tractor will not raise.
IF the rest of the hydraulic system has normal pressure, then the control valve for the 3 point may be faulty, or ; the hydraulic cylinder that raises/lowers the 3 point arms has failed (the sealing ring on the internal ring has torn)
Posted on Jun 20, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
Just bought a John Deere 325 mower. Deck will not raise or lower. Center knob is locked up will nor turn either direction. Lever that raises deck does nothing. I got no manual with it. Used
Study the mechanism and linkage for moving the deck and then take appropriate action. If you see how it works and familiarize yourself with it you will know what to do in such times. You might also consider getting a service manual or Googling the issue.
Aug 28, 2017 | John Deere Garden
John deere 4310 temperature gauage not working
Thermostat in 4310 did nt help
I don't know about next move, but my first move would have been to check and clean the connection to the temp. sensor and ground.
We have had several machines do this, sometimes going up dramatically in temp. readings.
It turned out each time to be a change in resistance in the circuit. The temp. sensor changes resistance as it warms and cools, this means that when the circuit gets some corrosion or dirt in there the temp. reading changes too.
Jun 25, 2017 | John Deere Garden
Solenoid 2305 john deere
When bolting it on, be sure good and clean. Its your ground for solenoid.
Jul 26, 2014 | John Deere Garden
John Deere L110 won't start.
check the solenoid on the bottom of the carb see if there is power if no power check the safety switch on the brake/clutch if there is power remove the solenoid and put power and ground to it to see if it opens if not try and clean it with carb cleaner if that works and opens remove the bowl from the carb and check the needle valve on the float make sure it moves
Sep 01, 2012 | John Deere Garden
John Deere 310G that the hydraulics quit working
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 310G
May 29, 2017 | John Deere Garden
John Deere stx38 won't move
i have the same problem, where is the differential release that you say to check after raising the drive wheels
Mar 14, 2012 | John Deere Garden
John deere stx38 wont move transmission locked up?
Jul 14, 2009 | John Deere Garden
Sprinkler will not move forward properly
I have 2 John Deere 4010 traveling sprinklers and they both do the same thing. I took them apart and the plastic worm gear has flat spot on them. I am having difficulty finding replacement parts.
Mar 08, 2009 | John Deere Gilmour Traveling Sprinkler -...
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
