Question about Procom ML250EPC Heater
I need a wall mounting bracket for a procom 5 brick heater.
    Scholar:
  • 146 Answers
You can contact Allparts Equipment and Accessories at 1-877-475-5660
They should have these items in stock.
Posted on Oct 16, 2010
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Need wall mounting brackets or base to sit on floor
Hi lyn , where is local for you , town or city please , DO NOT POST YOUR ADDRESS .
Jul 08, 2010 | Procom ML300TBA Heater
I have a procom blue flame heater it has ran for 2 seasons and still heats well. The problem I have is that there is a white powder deposited in the burning area and it seems to test positive for lead with...
the procom is manufacturered overseas in china where lead monitoring is at an absolute minimum. the refractory brick contains silica which is sand and under heat changes to glass. this could be where you are getting the lead reading. try to find refractory brick that is basically clay with little silica.
Oct 17, 2009 | Procom (177653) Utility Heater
Need manual and wall mounts
I don't have a manual for the HGA, but that heater is identical to the ML300HBA, with the exception that it has a black piece of sheet metal that hides the flame.
The manual for the ML300HBA can be downloaded from my website:
http://www.stpaulmercantile.com/ML2030BF.pdf
A wall mount bracket comes with the unit, but if you don't have one, you can call Procom Customer Service at 877-886-5989 or World Marketing Customer Service at 800-776-9425 and ask for one.
May 06, 2009 | Procom ML300HGA Heater
Flame
the first thing I would do is pull it apart and give the bricks a good cleaning with a wire brush to get any soot off. If they are broken beyond the point of replaceing them in the unit you will need new bricks.
Jan 18, 2009 | Desa International GWP20T GLOWARM Wall...
Infrared Heater - flaming thru plaque
I had this problem. From using the center brick most of the time, lots of dust bunnies build up in the gas chimney behind the brick.
Tie 2 pipe cleaners together with a small perpendicular circle at the top and carefully remove the dust bit by bit by twirling the cleaner.
The brick should fire like new if it is carefully cleaned out.
Jan 15, 2009 | Procom ML060HPA Heater
I was wondering where i could buy a replacement pressure regulator for a procom model ml250tpa
Try Procom Customer Service at 877-886-5989. Or call Kozy World at 800-776-9425 and tell them you have a KWP324 (same as ML250TPA).
Dec 27, 2008 | Ace Hardware ML250TPA Infra-Red Wall...
Flame shooting to high
call the gas company to have it serviced sounds like it needs it
Nov 23, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Procom fireplaces
Empire makes a wall heater that is direct-vent that looks similar to vent- free wall heaters. Here is a link to a website that sells their products... http://www.mastersalesonline.com/empire/index.html. I am not sure of the prices you will need to call the on-line store. I hope this helps you.
Jul 08, 2008 | Procom ML300TBA Heater
Procom ML250EPC Heater Logo
144 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
