Question about KitchenAid Kitchen Ranges
Kitchenaide selectra electric stove/oven model KERI 500 YALO - stove works, but no digital panel display or oven. When unplugged and replugged, there is a snap sound like an internal circuit breaker.
  • 833 Answers
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric range
The problem is caused by a shorted BROIL relay on the Electronic Oven Control board. I have experienced this problem before. The oven will continue to heat because it's being provided a constant power source. You are right to assume the reason for the oven temp error. This is common too.
Here's a TEMPORARY fix you can try:
1. Secure power to the range and remove the back panel from the console.
2. Unplug the BROIL element wires from the EOC and wrap them with electrical tape. It should be marked on the circuit card.
This will leave your broiler out of service, but you should be able to use the bake function. This should only be a TEMPORARY fix. The real fix is to replace the EOC. In the mean time, DO NOT leave the range plugged in while not in use (especially, if you are not going to be home, or while sleeping). This could be a definite fire hazard. If you post back with your model number (located around the oven door, or bottom drawer opening) I can give you an idea of how much the EOC would cost, and give you advice on how to replace it.
Posted on Feb 11, 2008
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
Treefrog15
  • 127 Answers
SOURCE: Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
partimage.aspx?imgid=z3bqljffahrfmja4mdazoc9mufcvc290b2hwdhjhcc8%3d
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Posted on Dec 23, 2008
SOURCE: oven controls all work but off buton not working.
This is the Membrane switch which is faulty. I had mine replaced once already. These units cannot be repaired, they need to be replaced. Apprently it is very common and you should report this to your local ESA (Electrical saftey authority) this is a very dangerous problem. The ESA can have this item recalled if enough people lodge a complaint. The round Stove top knobs on these Ranges also have a tendency to switch on when bumped, very dangerous too.
Posted on Oct 19, 2009
Hi, I have a Selectra 30 and the panel has gone dark and the oven door is locked. If I unplug it and remove the back cover I can unlock the door manually. When I plug it back in the door locks again and...
First of all, why did you post a question about an oven under a dishwasher question? What is a Selectra 30? That is not the model number. The model number of the dishwasher in the subject does not help. Without knowing anything else, I would say you have a bad control board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Dec 17, 2014 | KitchenAid Kitchen Aid Superba Series...
Display panel control
I had the same problem with my Maytag range. I pulled out the stove and unplugged it. I took off the back panel that protects the digital panel that controls the oven. There was dust all over the electronics. I got a can of compressed air that is used for computers and blew all of the dust out. Plugged the stove back in and it has been working fine since then. Dust can create static electricity. The replacement panel is $300, plus labor.
Nov 28, 2013 | Maytag MER6769 Gemini Electric Kitchen...
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid oven display not working
Is it digital display? If so, Oven control module (display) May need replaced.
Mar 08, 2009 | Maytag MER5530 Electric Kitchen Range
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
KGSA906PSS
Took me almost three months to get a new range, and kitchenaid still insist it is an "isolated incident"... They need to be exposed and sued...
Aug 17, 2007 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen Ranges Logo
245 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
